Good morning!!!!
   / Good morning!!!! #45,061
When our grandson stays over, he usually gets me up before the alarm can ring, although this morning the woodpecker again had me awake slightly before he came crashing in. Ben was keen to go out with me first thing to check on the sheep. Instead of waiting for me to open the gates, he has discovered he can now climb through in seconds.
Thanks for all the tips on welding rods.
RS, I don't fancy a quick sun tan, so I'll keep covered as you say. At the moment it's way too cold to think of being out in only a shirt, let alone a shirt with short sleeves. Many years ago I had a thick leather jacket that I stopped wearing due to the lack of pocket space for the ever increasing amounts of junk I seem to carry around nowadays. A couple of weeks back I had a rummage around and found that fortunately it had escaped the charity clothing collections and it is now seeing life again each time I play at melting metal.
   / Good morning!!!! #45,062
43 going to sunny 69 with a bright moon to make it easy to take Coco out for a quick walk.
Eric, I can remember when I was small and limber enough to crawl through things like Ben.
Kev FTN - very impressive load on that new grapple you added to your bucket.
Once the rain dried, mowed everything but my trails yesterday, and the newly replaced steering gears held up well. Fingers crossed I can get another season out of it.
   / Good morning!!!! #45,063
Good morning all. 38 here this morning, going to 70. Calling for showers Monday and then Tuesday through Thursday night so we should get some. Earlier this spring we were getting heavy rains and I had to go down in the pasture and dig a ditch so the water would not run toward the road. Now it don't matter because it is dry.
Are you Texans able to get around and start cleaning up much or is it still to wet? Ed
   / Good morning!!!! #45,064
Good morning friends. 61 degrees at 5:30 am and forecast is to get to high 70's this afternoon.
Yep Ed, starting to dry out but, still have areas too wet to mow or even drive across. Thunderstorms forecast for mid-day.
The ark is still on standby!
   / Good morning!!!! #45,065
2016-04-24, 0644
28 right now...high of 56 today. About the same as yesterday's weather.
Today's projects are a continuation of yesterday's projects...
The bathroom faucet in a step-daughter's rooms is done and I started re stacking the wood pile. I'll try to get to the porch glider when it warms up a bit.
   / Good morning!!!! #45,066
Good Morning! 52F @ 4:15 AM. A mix of clouds and sun this morning followed by mostly cloudy skies and a few showers this afternoon. Thunder possible. High 71F. Winds WNW at 10 to 15 mph. Chance of rain 30%.
Eric, that leather jacket sounds like a good idea, but be watchful for sparks jumping into the pockets. DAMHIKAT... :laughing:
Dragged the neighbor's trailer home yesterday morning, and pretty much spent the day working on it. The electrical lead for the lights was in bad shape, so I took the one off my office trailer and swapped it out. I was rewarded with running lights, but no brake lights. The right side was wired backwards, the contacts in the left side were corroded, and after replacing the right lens, all was right with the world. Even got the trailer brakes working. I was about to weld up a couple short lengths of 2x3x1/4 tubing for a cross brace under the receiver hitch when I remembered an old hitch a friend gave me several years ago. It was still laying under the office trailer, and after some quick work with the porta-band it was welded across the trailer tongue in a good location to mount the winch. Used a couple of the battery lugs the neighbor supplied to make up a power cable for the winch, hooked up the control button, and... nothing. The relays aren't clicking even though they're getting power, and I think I smell a bad ground. The mounting plate I made up for the solenoid housing got a nice thick coat of paint, and I don't think the primary side of the solenoids is getting grounded properly. But by that time it was long past dinner time, so I'll have to test my theory after breakfast.
Also looked up the specs on the Westfalia camper van, and it seems like I'll have a couple inches clearance as it rolls into the garage. Now all I have to do is roll stuff around in there so there'll be enough room to work on it. Might still be kinda tight, but I'm used to walking around sideways. :laughing:
Oh, and I did a little research on suspension systems, and may have found what I'm looking for:
Ranch Racing! 1967 Ford PreRunner vs 1989 Volkswagen Van! - Dirt Every Day Ep. 49 - YouTube
Have a good'un, guys!
   / Good morning!!!! #45,067
43 high of 73 later today under plenty of sunshine. Church and then who knows what
Weather for May looks stormy Texas more big rains and one may make it to east coast. June hot then hotter not good for those who work outside. Be safe Texicans
   / Good morning!!!! #45,068
Chessies really love to work ours did
   / Good morning!!!! #45,069
Good morning, i was surprized to see the frost this morning it's 33 now headed to 70 today. I got to mow with my new x580 JD yesterday it cut my time down some. I put chains on my 335 to mow the rough area and it goes like a tank now. I didn't get my tators planted ran out of energy and time, but with these temps they don't need to be in the ground yet. Everyone have a great day.
   / Good morning!!!! #45,070
OH yeah i member them day's as well.
   / Good morning!!!! #45,071
50 this morning and headed to 81 today. Another foggy morning means good moisture and good humidity.
Managed to start spraying some fences yesterday. But spent most of my day with wife and boy. Boy's starting to feel better.
As for today well it's a chicken and cow caring day. Might try to do some mowing. Depends on how much it drys. Barn calves need hay also. So will have to move a bale up.
Have a good 'en.
   / Good morning!!!! #45,072
IT was cool this morning, but only in the 40's, upper 60's later. Planting flowers and mowing grass today.
   / Good morning!!!! #45,073
Coffee has been poured. 58° with patchy clouds this morning. Heading to 78° with mostly sunny skies. We made it to Carlyle, IL yesterday. Not a bad drive. But traffic around Kansas City was a mess. Going to spend a couple days with friends before we head home.
Good Morning All.
   / Good morning!!!! #45,074
Good morning, sunny and will get into the 80s today. Good day to clean up all the sticks and limbs that have fallen around the house. The house is the only area I have not cut yet. Looks like you guys out east got the frost some here got yesterday.
Nice picture of the grand-son Eric. :thumbsup:
No real plans.
   / Good morning!!!! #45,075
51F and sunny @ 10:00 ... high today is supposed to hit 65F ...
Grapple thread updated: finished welding expanded metal backstop on lower frame, fixed hydraulic leak, swapped hoses around and covered them with sleeving, and trimmed the bracket for the front hydraulic outlets. Still need to install Weather Pack connector on the wiring for the diverter valve.
Neighbor kid brought over a dump truck load of ash from a job they did yesterday. That needs cut up and split.
Also managed to clear about 75' to 100' of fence line ... still have another 800' to go.
Need to start seriously thinking about mowing before it gets out of control.
   / Good morning!!!! #45,076
mkr,
Nice lookin' piece of ash ... and nice bucket grapple too ... :thumbsup:
   / Good morning!!!! #45,077
Eric,
That leather jacket should be good for keeping the red-hot boogers at bay. I think I may have one that got junked when we attempted to clean it ... probably should see if I can find it and dig it out.
   / Good morning!!!! #45,078
Good morning all. 63F heading for 80F windy, partly cloudy skies. No rain here till Tuesday night. I was north of the heavier rain last week only got about 5 inches. Been to church choir sang well, have some consulting work to do. Couples golf tourney and bike ride fill out TMA. Have to start prepping for next week trip to STL, gonna to some consulting and being a lab rat for Alzheimer research.
   / Good morning!!!! #45,079
Good morning! 74˚ inside and out, cloudy, 60% rain forcast for today along with the squishy pasture has the tractor confined for another day.
Gray2 had a sucassful hunt and is munching on a vole on the front porch. We had to stand in ankle high water in the field yesterday while gathering dewberries for another pie.
Mostly_gas will research be drug or food based?
   / Good morning!!!! #45,080
RS great grapple !!
Don saw Christy on the Dallas news Friday night, Figured had to be her, how many female wranglers are there?
Kev nice grapple and train car pics
Drew good luck with your organic insecticide, love your boating stories, strictly lake and river boater myself.
Sam / Ed great stories, if you remember that you forgot, it does not count as a forgot :)
wngsprd, great forest pic and fish story, there pools like that in the Ozarks, just have smallmouth and perch and bluegill :)
Eric cool picnic !!
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
iDrive TDS-2010H...
LEEBOY 8530 ASPHALT PAVER (A60429)
LEEBOY 8530...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
