Good morning!!!!
/ Good morning!!!! #206,701
marvelous pics Frits, please thank your daughter
quick trip downtown to get a few things from supermarket, including grapes.
friends coming for lunch and wanted to put some out for nibbling.
They are bringing Jersey Mikes turkey hoagies for us.
going to sit outside on a very nice day.
sounding ominously successful for the LS, David can the peanut gallery start cheering? :giggle:
Buppies, sorry dinner out wasn't fun. Better luck next time, different place, different hour?
/ Good morning!!!! #206,702
Good morning TBN!!
50 this morning and gloomy with .13 rain overnight.
Another day on the tractor yesterday.
Happy, nice work on the bridge, wondering whether you welded any support structure between the two pipes ?
It's funny you should mention this. I thought hard about welding the two together and decided if I were to do that the potential for taking out both tubes in another 100 year flood would greatly increase. I do think I am going to get rebar or angle and weld them together to basically build a cage for rubble in the center on both sides.
Then use more to create cages on the outside edge to catch rubble. That way I would hope the rebar would tear away. The whole thing is going to get slathered with a few yards of concrete as the final step.
Foreman stopped by for a little bit to make sure I wasn't slacking :)
He got a bath at the end of the day!
Very sloppy. I think I could drive the truck across in a pinch now.
Hoping to get a load of rip rap and gravel to tame the mud.
Not paying enough attention to wear the clay was going. Closed the new side up by about 25% with clay and had to dig it back out.
Today will be R&R. We have flooding concerns tomorrow and one dry day in the forecast. Not really a good Spring project but, I will muddle through. Quite literally.
Time for a second cup
Everyone have a great and safe day!!
/ Good morning!!!! #206,704
Good Morning Happy,
I think that’s a great idea, it was just a passing thought on my part.
Fine job so far 🙏
/ Good morning!!!! #206,705
Morning all, 62 going to 81 and sunny
Happy Mothers Day.
Got the corn "field" dug up and roots out. Easy with a tractor and Piranha bar :)
Now to till and plant, and wrap the wire around, once the clips show up.
Drive went all over on back roads, some nice areas around West chester etc.
No planters, but got to look at sneakers for wife.
We saw an old 356 Porsche off to the side of the road, with some help. I remember old car failures quite well, though only got stuck in mine once, and luckily only a few miles from home.
My father had a 356 convertable replica (speedster) for a number of years.
Be well,
/ Good morning!!!! #206,706
60F and sunny @ 10:30, heading up to around 76F for the day's high.
Got front, back, and almost all of the east side mowed yesterday after I got back home:
Front was very tall and thick - highest parts 6" (or better) - mowed that with the deck set to 3.5".
East side and back not quite as bad, mowed those with the deck set at 3".
All of it will need gone over again later today once the grass has had a chance to dry out to spread the clumps.
Woman already on a tear this morning, out picking up sticks on the west side. That side has not been mowed so far this year.
I did manage to get about 1/2 the front cored a week or so ago when the ground was fairly moist.
On the agenda for today:
More juggling and rearranging things in the barn ... including the nearly empty 330 gallon IBC tote ... so I can unload the diesel I picked up yesterday. Need to get that done before the rains arrive when access will become a problem due to soft ground and mud.
Maybe get the west side mowed ... which will finally get the mowing caught up for the first time this year.
Check the underside of the deck on the Cub. I suspect it needs cleaned off, although it's not acting like it's real bad yet.
Ran out one tank while mowing yesterday so one of us will probably make a trip down to the corner for another gallons of gas.
Rustle up a tarp and get fence posts tarped before the raindrops start falling.
One of the more recent projects here was to get Wi-Fi access out in the shop. Since the building is 300+ feet away from the house and is concrete block construction with a steel overhead door the Wi-Fi signal was pretty much non-existent.
Didn't want to run hard wire due to the expense and time and effort involved and since wireless solutions have gotten cheap enough and offer good bandwidth decided to go that route. Went with a pair of TP-Link Outdoor CPE's with one mounted up at the shop and the other mounted on the northeast corner of the house ... the 710 model specifically:
These have a gigabit Ethernet connection, up to 867Mbps bandwidth, up to 15 kilometer range (clear line-of-sight) and operate in four different modes (dedicated private connection for connected equipment, connection+ WAP, etc.)
Set up was a piece of cake.
Attached an Apple Airport Extreme to the one up at the shop, which provides Wi-Fi inside the building plus another 3 gigabit ports for any hardwired equipment.
They don't come with J-Mounts ... but I was able to repurpose the old J-Mount from the Direct TV dish to mount the one up at the shop (glad I hung onto that ... ;) ) but had to pick up another J-Mount from Menards ($13) to mount the one down at the house.
Very configurable and thus far seems very reliable ... and will hopefully eliminate the annoying throttling on the cell phone data plans.
Need to get moving and get started on getting some things done.
Hope everyone is having a decent Sunday ... (y)
/ Good morning!!!! #206,707
Happy Mothers Day
66°F and .20 inches rain.
A great day mowing yesterday and hope to continue on the Laupahoehoe end today once it dries.
Otherwise nothing big planned. That little girl still requires lots of attention during the day. She has figured out she can slip between the fence stiles. Didn’t go out once in her new crate but of course I woke up 3 times to check on her and give her opportunity to go out. Geesh.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #206,708
I made the executive decision that today would be an energy conservation day. Rain coming on Friday according to the long range forecast, so that is when I will seed.
Monday is going to be an expen$ive day I think.
On the way to the shop I will grab a grand out of the bank.
/ Good morning!!!! #206,709
Good morning all. Happy Mother's Day to all the wives and mothers out there. 52ºF for the start, mostly cloudy, breezy. Forecast for light wind, clouds increasing, and high of 76ºF. made coffee to start day, Help setup, attend, help tear down chapel, breakfast with group, and starting to catch up on posting here.
Resuming Friday 7:47 PM CDT post 206,651:
Randy(wag) glad Thursday was so productive for you. Sorry about the possum in the cat food. My experience with critters and cat food is they need very strong persuasion such ad relocation or more to quite feeding there. Hope paddock switch and clean up went well.
Bill sorry meter leaked. Hope you can fix it. Glad house tank ready for summer. Nice to hear wood fairly fry already. Hope CEL is an easy fix and maintenance goes well on Dodge. Hope tractor not too expensive repair.
Saturday morning 3:34 AM CDT:
Ron glad you got a mix of getting the car washed and garden weeding and some energy conservation done. Hope you got energy conservation time in yesterday. Nice squirrel pic.
Drew good to hear all is working on HVAC. Hope you found something fun to putter with. Glad you found good deal on bird houses. Have fun with the owl house build.Heard an owl hooting away last night. The $2.60 was about 10 cents cheaper than everyone else. Wednesday forecast for 100ºF :(
Bill hope meter people help you fix meter. Hope tree went well.
Billy nice rain amount, hope a lot of it soaked in. Hope you were able to make dent in to-do list. Hope you coffee all turn out good.
Drew hope you can persuade squirrels to feed else where, but not sure that is even possible. I use Gas Buddy but don't use run down looking stations. I would choose a station where anybody comes out and talks to me :)
Frits glad you got more rain and catching up. Glad heater working. Sorry about issue with Iphone, sounds battery related to me. Glad miter saw has new cord and new home. Good to hear D not missing Hawaii trip because of knee/pain.
Thomas glad you are ALL caught up on rain, hope you can dry out some. Hope putter was productive.
Happy(NC) hope bridge holds up to rain. I looks like you are close to getting the bridge in usable condition.
Drew when I lived in the Ozarks you all thought about river levels because of the low water crossings and how fast rivers came up.
Don sorry to hear sunflowers are tardy to bloom. Great set of pics
Fatjay nice weather, congrats on getting one through college. Hope chicks are doing well.
Happy must be a fun project, but living without the bridge not fun.
Buppies since i am alone in the house I put thermostat on A/C. Hope you have a nice Mother's day with Holly home and Son in town. Enjoy seat time while mowing.
Ken rain with no runoff is the best way way. Hope good drive with the wife.
RS now that is a stack of posts! Sorry about the over fill. I usually underfill by a quart, then check after it is off the ramps. Thanks for planting bed pics. Hope you were able to get all the diesel fuel.
Drew sounds like your trying to get RS in hot water ;) Glad you got rid of caterpillar nests.
David glad you had great day of mowing. Hope Hilo end done.
Dennis they are huge! thanks for sharing.
Bill when I drive through Oklahoma reservation gas same price as everyone else/ Sorry wind messed with your tree work.
Drew glad you got outside tidied up and push mowing done. Hope you got good nap.
RS nice score, sound like you close to being done.
Lou big time over kill for anywhere I have lived!
Drew auto maker engineers have more choices when building car engines, but the auto makes have trouble making decisions spending more to get better quality.
Don hope your hot weather gets the pool warm enough for use. Wednesday forecast for 100ºF, old record 95ºF.
Kyle Congrats on son getting academic achievement award. Glad you beat rain mowing, sorry not more rain. Good luck with Gator carb, I trust you have all passages blown out? Hope heart procedure goes well for your mom.
Randy(wag) glad paddock swap and clean up on #6 went well. Hope church was good.
Dennis glad good breakfast with crew. Sorry oil plug so hard to get out. Glad you found new plug and filter wrench.
Buppies hope you get a good engine.
RS glad wife can still make meaningful contributions to all the outside work. If I had tried Drew's suggestion with my wife, I would not be posting today :)
Sunday 3:43 AM CDT:
Ron glad you could heal neighbor with old deck. Hope you got some meaningful energy conservation in. Nice pair of cardinals
Drew nice warm up in forecast, hope lunch with friend was good.
Bill hope reseeding went well.
Phil glad neck and hands finally doing better. I have the same issue in front, need to get a shade tree going. Love the wood work pics!
Scott(vt) glad you passed the Technician class license test sorry you barely miss the the General exam. Hope they reinstate your old license. Glad you have help getting antenna up for new system, sorry wife not enthusiastic about antenna. Hope church was good.
Thomas hope putter and trimmer work all went well.
Buppies hope you finish mowing before rain hits. Sorry Holly got upset at dinner.
Frits glad wife happy with the tulips. Good to hear Z-turn greased up. Nice you can mow and listen to music. Thanks for sharing D pics.
More catch up later
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid, blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad dementia, /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, ******, Ukraine war, hurricane victims, and Country.
/ Good morning!!!! #206,710
I could use some advice on a caulking/sealant product.
my shower head piping goes through a hole in the tile with quite a bit of
clearance, and no support all the way back to the connection.
I want to support the piping where it comes through the wall, and let that area take the
pressure when the showerhead is taken on and off, plus there's a bulky water filter up there too.
too much weight on an unsupported pipe. And of course the other end failed and had to be replaced.
I'd like to preserve the new part and I can't imagine this lasting all that long getting bonked back
and forth, no matter how careful I am.
so...plain silicon caulk? I'm wary of strong industrial adhesives in case the pipe does need
replacing in the future. I guess I'd like something medium strong that I can just squeeze in the hole
around the pipe and have it solidify, all hidden by chrome face plate.
this is a mechanical contact between tile/some backer board and a copper pipe.
whole tube of silicone caulk is two bucks. I'd waste 99 percent of it since likely years before I need it again.
and then those tubes are always hard as a rock.
which is why I buy small disposable quantities now.
does plain silicon caulk get hard enough or do I need some kind of hybrid?
something the next plumber will not swear at me because...
a rubber grommet that pushes in to grip the pipe might work too.
that would take careful measuring
hmmmm
I think two bucks worth of sealant is a cheap enough fix...
now Popgadget would be building that grommet to perfection in his deposition machine.
I don't think he can do flexible/rubber stuff but ?
/ Good morning!!!! #206,711
59F clear sky.
Been good day all in all,new trimmer did good job but going to take little time balancing trimmer weight compared to old trimmer :unsure: some place couldn't trim water setting on the ground :( first time mowing went well couple places were close to getting stuck :oops: blackflies made their debut :( and this week weather go.ing to be warmer and they should be hungry. :(
Plans for the evening set on the deck enjoy smooth cigar what for the critter and stars.
Enjoy your evening all.
/ Good morning!!!! #206,712
hmmmm
Sounds to me like the pipe has lost its support inside the wall. They usually are shored up with clamps on 2x4 supports. If the wall leaks onto the supports, it will rot over time. Can someone get to the inside of the wall from the other side?
/ Good morning!!!! #206,714
hmmmm
I like an access door on the backside of plumbing but the one bathroom remodeled the contractor didn't put one. When I had to replace the shower faucet a plumber friend said just buy a decorative chrome plate which I did. I cut the wall about an inch smaller than plate which made easy access.
They make round chrome covers for shower head like 3"-4" diameter like a large washer. Some have two screws either side.
/ Good morning!!!! #206,715
Good (Monday) morning. Overnight Low of 6.3C and it's presently 19.3C, clear & calm.
It looks like I'm going to need a trap for this possum... it's getting bolder. Not aggressive, just stubborn to leave Penelope's food. I needed to don my welding gauntlets to physically grab it last evening.
Just to reassure you, there is no rabies in Australia. One of the reasons that we have such strict quarantine laws.
I'm not sure what I'll get up to today, although I heard a rumour at Church that there may be a 'sign site', that I didn't put up, that needs taking down. So, perhaps an afternoon drive today.
/ Good morning!!!! #206,716
Got grass mowed still sticks in side yard hit a few grass was over one foot tall. The Lexmark ate it up that 29 hp is owerful but thirsty
Hope all mothers had a great day
/ Good morning!!!! #206,717
hmmmm
What about that spray in foam, then seal?
/ Good morning!!!! #206,718
Coffee is brewing. 40° with clear skies this morning. Heading to 82° with mostly cloudy skies. Did Garden Pond maintainace yesterday morning. Also did some maintainace on pond vacuum. The watched NASCAR race in late afternoon. Today plan to get grass cut around buildings.
May Flower Full Moon.
Everyone stay safe and well.
Good Morning All.
/ Good morning!!!! #206,719
Pretty usual Sunday for me, except took my wife out for Mother’s Day. She got a free meal.
Long phone call with son in TN.
Taught my course, should be done with it in a couple weeks.
Been up since 1:30, finally came downstairs to sit in chair.
/ Good morning!!!! #206,720
Good morning, the low wads 47 and going up to 72°F. Wind SSW 7 mph. Sunny!
I'm off to the garage at 8, bank first then garage and get my summer tires on, oil changed, check engine light dealt with AND the lose gas cap indicator issue.
Wagtail, can you not give your possum lead poisoning?
Have a safe day all
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A60430)
UNUSED SDLANCH...
1991 International 4900 Box Truck (A55315)
1991 International...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
KUBOTA L3410 TRACTOR (A60430)
KUBOTA L3410...
