Glow Plug Use
/ Glow Plug Use #1
wsp617
Wisconsin
JD 1070
I have an '89 JD 1070. It was in the low 50's the other morning when I went to start my tractor. I wasn't sure if one needs to use the glow plugs at that temp but I figured it wouldn't hurt. When I went to start it, it just rolled over but didn't fire. Now, this tractor ALWAYS starts so I was confused. I let it sit a few minutes and then she started right up. Was I wrong to use the glow plugs or was there possibly another issue?
/ Glow Plug Use #2
First Welcome.
I don't know what caused the tractor to not start. I would think it would always start with glo plugs no matter the weather.
As for when you NEED glo plugs, I never use them unless it it below zero deg F. My tractor sits in a unheated shed. It will even start then but it starts easier with the count of 5 on the glo plugs.
/ Glow Plug Use #3
It depends on the tractor, we have a Kubota L3830 that only needs the plugs when it is below 30F. We also have a Kubota B7500 that needs the plugs every time you start with a non-warmed up engine, even when it is 90 out.
Aaron Z
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
