Generator breaker vs. regular breaker-is there a difference?
   / Generator breaker vs. regular breaker-is there a difference? #21
You have the wire which saves you a big bundle. You have the ability to buy a interlock sheetmetal that fits on your panel. I dont see how you really can save money using a 50 amp breaker when a 30 is more suited for the job if your genny is rated for that. nothing can replace the peace of mind with right sized breaker.
To answer your first question , just like everyone else says - a breaker is a breaker. nothing special about a generator breaker for hookup to go in your breaker box. Save your 50 amp for the future or sell.
   / Generator breaker vs. regular breaker-is there a difference? #22
And a SquareD 30 amp breaker is about $10 IIRC, not worth it IMO "Just in case" the generator breaker (which is probably the cheapest one they could get) is bad.
Aaron Z
   / Generator breaker vs. regular breaker-is there a difference? #23
Don't get grumpy, I was just agreeing with your stern warning in your earlier post.
OK, After re-reading your post numerous times I can see how you meant to be agreeing with what I said- it just didn't come across that way, part of the problem with the written word...
I just don't want someone to misunderstand the seriousness of wiring things correctly:)
   / Generator breaker vs. regular breaker-is there a difference? #24
I think you might want to work on your ability to recognize sarcasm. Just saying.
BTW, a breaker is a breaker, and interlock kits are great.
I went back and re-read the post in reference and can see how he meant, as he later stated in another post, that he agreed with me. I mis-read his meaning. It was not clear to me originally, and I did not want someone to end up taking this issue as if it is not a significant subject. Sometimes hard to discern the meaning one conveys in the written word.
   / Generator breaker vs. regular breaker-is there a difference? #25
As previously stated a couple of times. It's all about the generator breaker and main breaker having a defeat proof interlock to prevent both from being closed at the same time.
Ground wire and neutral wire is a contentious issue and often miss understood.
Don't anybody bother trying to say ground and neutral is the same either. As soon as you do, it's proof you don't know the theory.
The neutral is an insulated load current carrying conductor which is referenced to earth potential voltage.
The ground system is not to conduct load current. It's designed to hold metal equipment in services, buildings and machines to earth potential . In normal operating and during fault conditions.
   / Generator breaker vs. regular breaker-is there a difference? #26
Agreed. I've gotten myself in trouble texting more than once. The lack of inflection makes it difficult. I think that's why people use the smily faces so much.
I also agree that electricity done wrong can have dire consequences.
   / Generator breaker vs. regular breaker-is there a difference? #27
The 30 amp recepitical is protected by the 30 amp breaker on the generator not by the 50a breaker..
The only time the outlet gets power is when the generator is running
Yes, but doesn't that presume that the generator is the only thing that is ever plugged into that outlet? Is there any other type of appliance that might plug into that 30A outlet that would draw more than 30A, or that wouldn't have its own breaker protection?
   / Generator breaker vs. regular breaker-is there a difference? #28
The interlock will keep the plug (its a male connector, not an outlet, more of an inlet) from being hot if the main is closed, so the only thing that will connect there is a generator. And if something is wired incorrectly enough to mate with the connector, no voltage will be present.
The breaker is there to protect the wiring in the house, but it's the breaker on the generator that will trip if something goes awry.
Breakers are installed to protect what is downstream of them, so the backfed breaker would really only be protecting from the buss bars in. If the generator was running, and you drove over the cable coming from it causing a short, it's the generator breaker that would trip. The breaker in the panel would not see the over current condition.
Every one of us has wires that are undersized for the breaker rating they are on, unless your TV and clock radio and everything else you have plugged in has a 12 gauge line cord.
As far as the connector, a standard Edison female receptacle is rated for 15 amps, yet they are usually connected to a 20 amp breaker.
Sorry for jumping around, just a bunch of things I thought of reading this thread.
   / Generator breaker vs. regular breaker-is there a difference? #29
That's an interesting point. I wasn't thinking about the fact that the interlock will prevent the receptacle from ever being fed by the 50A breaker in the service panel.
Every one of us has wires that are undersized for the breaker rating they are on, unless your TV and clock radio and everything else you have plugged in has a 12 gauge line cord. As far as the connector, a standard Edison female receptacle is rated for 15 amps, yet they are usually connected to a 20 amp breaker.
The appliance cord isn't relevant to my point, since it's not permanently installed, nor inside the wall. My understanding is that NEC is designed to protect against hazards in building wiring, but it's Underwriter's Laboratory and their ilk that certify appliances. But your second point is definitely relevant, and just to be sure, I went and looked at my service panel, and sure enough, it's 20A breakers all over the place, but only 15A receptacles. Of course, a 20 amp plug will have a sideways prong and won't plug into a 15A receptacle, but what would protect the system if a 15A appliance was faulty and drew 20A, overheating the receptacle? I'm surprised the NEC doesn't prevent that situation from arising.
   / Generator breaker vs. regular breaker-is there a difference? #30
So what would protect the 30 amp receptacle from being overloaded? As long as this generator, and future generators, has a 30 amp or less breaker on it, you're good. But why not put in a 50 amp receptacle to match the wire and panel breaker?
   / Generator breaker vs. regular breaker-is there a difference? #31
The odd thing, or one of them, is that the duplex receptacle as a whole can handle the 20 amps, but either of the two outlets can handle 15 amps max. So it's possible to plug two 15 amp devices devices and trip the breaker, and that's only on one wiring device. Usually there are several on a single breaker.
And you are right about the line cords not being permanent and other associated points. I was just rambling a bit.
   / Generator breaker vs. regular breaker-is there a difference? #32
...as a side note regarding 15amp recepts on 20amp ciruits, which is the norm for multi-yoke circuits I'm also pretty sure the code: NEC (NFPA 70) says that if there's only one receptacle on the circuit it has to be fully rated (i.e. 20 amps). ....and 1 duplex receptacle counts as two.
Wow-really didn't expect this to go 4 pages, but it's a good discussion. I don't know why I didn't think of this before, but since I have the wiring and the breaker inside to handle it I could do a 50 amp male receptacle on the house and simply make up a "custom" generator cord out of the appropriate sized cable with a 30 amp male plug on the generator end and a 50 amp female plug on the house end. Then if I ever got a generator capable of putting out 50 amps I could change the 30 amp male plug to a 50 amp male plug.
   / Generator breaker vs. regular breaker-is there a difference? #34
Whatever you do, don't use a male to male cable, also known as a suicide cord. You never want live prongs. You want a 50 amp inlet on the wall, along with a custom 30-to-50 cord. The 30 amp end would be male and plug into the generator. The 50 amp end would be female and plug into the inlet. This would also always prevent feeding the cable with a 50 amp source and overloading the 30 amp end.
Sent from my DROID RAZR HD using TractorByNet
   / Generator breaker vs. regular breaker-is there a difference? #35
On the prior page someone mentioned UL as certifying electrical components. They do NOT certify anything- they LIST an item and that is all they do. It's a rating system that has to be followed. They test to make sure things meet a certain standard and then LIST the item as such.
   / Generator breaker vs. regular breaker-is there a difference? #36
Since you have the cable and the breaker I would get a 50 amp generator receptacle for the side of your house, garage, or where ever you plan on having your generator. Like you said, you'll have a lock out device so either the main or generator breaker can be closed but not both. You can then make a cable that can handle 30 amps with a 50 amp female to connect to the house and 30 amp male to connect to the generator. Or you could use larger cable that can handle 50 amps to future proof yourself if you ever get a larger generator.
As far as a breaker protecting just the downstream circuit, that's wrong. In the case of an AC panel the buss bars are able to handle far more power than the breaker so in that case that statement would be correct. But in the case of a generator you also need to protect the internal wiring of the generator.
   / Generator breaker vs. regular breaker-is there a difference? #37
That's why the generator has a breaker on board and doesn't rely on a customer supplied over current device.
   / Generator breaker vs. regular breaker-is there a difference? #38
As a homeowner you can do lots of work yourself including plumbing and electrical. It just has to be inspected by a qualified person and signed off on my the inspection agency of record. In my case it was the electrical company prior to energizing but since you obviously live in a permit zone, you may have to apply for a permit to do the work, then you can run the line, install the box and breaker but then the city or county inspector will have to sign off on the work. If you get a knowledgeable person then it may go ok if your work meets strict code requirements. My son (who is a certified electrician) once put in the main power supply lines to his house and used the correct size wire AND put it in conduit. The power company guy that came to look at it wouldn't pass it because "it has to be direct buried cable" and no amount of arguing that conduit installation is better than direct burial would convince him. Even showing him in NEC wouldn't convince him. We had to request a different guy to come inspect and of course he passed it with flying colors. Never did find out if they fired the other guy. Typically this can be the kind of person that inspects and can cause you some grief if they only know "this is the way we do it" type of action.
This is a typical event that happens all to often, and the reasoning behind it is "I won't pass it because I can mentality" as you mentioned some inspectors cause much grief and unnecessary expense to many homeowners because as stated they can. I don't know if you complained of this persons conduct but I think I would have for the sake of others he's done this to.
   / Generator breaker vs. regular breaker-is there a difference? #39
If the 8-3 cable you have is NM cable I think it's rated for 40 amps. I've always used #6 cable for 50 amp circuits. Some electrician please chime in.
43055 (A55851)
43055 (A55851)
iDrive TDS-2010H...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
