Gear drive vs hydro
/ Gear drive vs hydro #302
Larry,
un QED:)
The relief valve pressure/HST pump can be designed to stall the engine at, say 1/2(or 1/3 or 1/7, etc) the full pump capacity(go pedal actuation), with the appropriate downstream gear strengths, and therefore, the design torque to the wheels can be any value that the designer sets.
What I am saying is that the maximum torque does not have to exist at full go pedal actuation. This leads to the possibility that the maximum torque could exist at 1 mph(even if the gear ratio was 3 mph), or even lower. These are not inherent limitations, but design choices.
A gear/clutch given system would benefit from the impulse of the engine spinning as it is stalling out, but a designer would have to design that into the system as extra strength in the running gear, which could be utilized to full, not just impulse, effect by an HST(since that impulse does not exist in an HST).
What I am saying is that there are not inherent limitations to torque designable into an HST system, even if it only has 2 gears(as compared to a 8 or 12 gear system).
In an appropriately designed HST(with equivelant driveline strength design), the relief valve bypassing is telling the driver--if I were a gear tractor, my engine would have just stalled--.
re QED
I would note that tractors with creeper gears specifically and emphatically prohibit pulling significant loads while in creeper gears(presumably because one could pop something major).
Chris
/ Gear drive vs hydro #303
the creeper gear warning may be for flippage. i agree with your explaination too. but i'm not all that edecated...
don't they compete these things in tractor pulls?
jake
/ Gear drive vs hydro #304
dynasim,
Got to tell ya, after the first read that is clear as mud.
/ Gear drive vs hydro #306
Larry,
un QED:)
[[[What I am saying is that the maximum torque does not have to exist at full go pedal actuation. This leads to the possibility that the maximum torque could exist at 1 mph(even if the gear ratio was 3 mph), or even lower. These are not inherent limitations, but design choices.]]]
[[[A gear/clutch given system would benefit from the impulse of the engine spinning as it is stalling out, but a designer would have to design that into the system as extra strength in the running gear, which could be utilized to full, not just impulse, effect by an HST(since that impulse does not exist in an HST).]]]
In an appropriately designed HST(with equivelant driveline strength design), [[[the relief valve bypassing is telling the driver--if I were a gear tractor, my engine would have just stalled--.]]]
Chris
I thot about that when I was writing the post. However, when I followed thru on all the interacting variables it forced me to the conclusion that equipment is not set up that way normally. If you have a pump that will stall your engine while pumping only 1/2 its full volume at relief pressure you have got a pump rated for at least twice your engine power, or else a pump that is delivering higher pressure than designed for. The latter would only give short term benefit while destroying itself. So to be safe we need a 2x rated pump feeding a 2x rated motor. This case would give the HST range the ability to "gear" down hydraulically to equal the steady state torque capacity of a gear range twice as low. The pedal would be more sensitive tho, since it is capable of asking for twice the HP that the engine can deliver - it will stall quickly at full pedal. Also, costs of the bigger hydraulic parts factors against use of this method to an extent. Im guessing 2x is more cost effective than putting in another range, but that manufacturers would not go any further than this on tractors. Stepping up higher would be reserved for specific purpose built equipment where it is important to not have to shift, and that the $, weight, and size premium required by using much larger pumps and motors than actually needed to make use of full engine power would be worth it. Skid Steers probably fit this category.
[Since it takes slightly more pressure to flush more fluid thru the relief the max torque is only available at full pedal, at least momentarily. It is just not sustainable in your posited systems.]
[Dont see how you could possibly get it without eliminating relief. It would last til the 1st time you tried to pull a BIG load in hi range. No warning. Engine doesnt even bog with careful pedal. Pressure just keeps climbing til things move or break.]
[Not necessarily true, and most likely not. Rather - Sorry the wheels have stopped. If I were a gear tractor I might be losing rpm, but I wouldnt be wasting power pumping fluid into the sump thru a relief valve.]
larry
/ Gear drive vs hydro #307
I had an opportunity to see a gear tractor in operation today. A friend brought his JD over to unload 50 gal barrels from my dump trailer. I put 14 each 50 gal barrels in the trailer so when the feed delivery guy filled me up most of it would already be in barrels and I wouldn't be scooping it out 2 gal at a time with a bucket to put into a barrel (like last year.)
His cute lil JD gear tractor (about 30 PTO HP or so) has an adjustment to set the speed (sensitivity) of the 3PH but none for the loader so with any reasonable RPM the loader is really herky jerky, way too spastic for delicate control but that is not because it is a gear tractor.
Being a gear tractor he has optimized his routing to fit it and it is different from my routing using a hydrostat. He drives and positions the tractor to reduce the number of shifts and clutch actions he is required to make. Boy oh boy what a difference between his gears and my hydrostat. He nearly crushed me against the side of the trailer (I will not work on foot so close around a gear tractor again.)
We were using my barrel lifting clamp (HF $29) which had always worked perfectly for me (smoothly engaging hydraulics) and NEVER lost a barrel. His herky jerky hydraulics (almost like having on off switches not proportioning valves) dropped two barrels but close to the ground and they didn't turn over.
The hydrostat is just head and shoulders over a gear tractor for working to load/unload a trailer with pallet forks or bucket or chain(s). It gives far superior control in tight quarters and when inserting a pallet fork or nudging forward or back just an inch or two with smooth control.
I might not have been able to do the job twice as fast but I could have reduced the time at least 30-40% for the job and had much smoother control of in-close work.
I'm not trying to persuade any happy gear heads to change tractors, I'm just reporting an actual observation of a real world task. If you don't need fine precision control or fast convenient direction changes don't worry be happy with a gear tractor.
It is like welding to a degree. If an AC only buzz box does all you need and you don't want or need better then be happy don't worry keep your buzz box and let others go MIG, TIG, flux core, or...
Pat
/ Gear drive vs hydro #309
Larry,
I guess my point was that it wasn't necessarily true that HST's put less torque to the ground than gear tractors. I am not a tractor designer, so I don't know what they do. I do know what I would do.
Thanks for the insight.
Chris
/ Gear drive vs hydro #310
Pat
A 5$ flow restriction orificed fitting from the supply store would take car of all that...
soundguy
/ Gear drive vs hydro #311
Heck, why not use a Danierls senior orfice meter. That way you can change the orfice while the equipoment is operating.:D
/ Gear drive vs hydro #312
I had an opportunity to see a gear tractor in operation today. {snip}
Pat
From what you wrote my guess is that what you in fact saw was a heavy handed operator, the tractor having a gear transmission was incidental.
By your own analogy a competent weldor can achieve much better penetration and generally better results using a stick "buzz box" than a klutz with a super duper mig rig and a push/pull gun.
IOW, it isn't ABOUT the equipment and in many cases feature encumbered gear inhibits learning & skill development.
Running MIG "just like a hot glue gun" sometimes produces a pretty wash weld, but a pretty weld without good penetration is harder to do with a stick.
("Playing" an i-pod can get a lot of music, but will never make someone a musician).
/ Gear drive vs hydro #313
larry[/QUOTE]
Right, you'd be doing it wearing out your clutch.
Jake
/ Gear drive vs hydro #314
larry
Jake
Yeah. I love post count builders, I mean threads like this. :)
/ Gear drive vs hydro #315
larry
Jake
No, id shift to a lower gear if the bog became critical. Not too convenient, but much more so than changing a clutch.
larry
/ Gear drive vs hydro #316
I was thinking that too. No doubt in my mind tho that an HST would have eased the situation regardless of operator skill.
larry
/ Gear drive vs hydro #317
some of us are trying to make an occasional point here, will, while waiting for the next drinking game to start. when it's too early for that, it's kind of like 'king of the mountain'.
jake
/ Gear drive vs hydro #318
larry
and at least he could have gotten almost squished in a smoother motion..
(glad he didn't)
jake (the guy that was polking around a running snoblower yesterday) 'well it wasn't turning so i thought i'd give it a spin...'
/ Gear drive vs hydro #319
I guess we will all buy what we think best suits our applications. The bad part is....... what we think is best for us also should be the best for everyone else. Both transmissions have their good points and bad. I know my choice and the reason for that choice,but my choice should have nothing to do with your choice. I would imagine that the gear vs hydro debate will go on again in the not so distant future. Albeit on a lesser intellectual scale than this time.
Sincerely, Dirt
/ Gear drive vs hydro #320
larry
Weren't most of the heavy handedness problems with the loader controls ?
I lack confidence working around OTHER PEOPLE on tractors anyway, but I think my self preservation instincts have a better chance if I see a tractor lurching towards me than one gently creeping up to squeeze me softly against a wall or push me gently over a ledge )-:
Again, this is about the operator not the tractor - but I would still prefer that the tractor NOT mask his/her incompetence.
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
CAT D6T SU Blade (A68134)
CAT D6T SU Blade...
2013 C&M TRAILER T/A 20 UTILITY TRAILER (A67714)
2013 C&M TRAILER...
2015 Jeep Cherokee 4X4 SUV. (A66738)
2015 Jeep Cherokee...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
