Deciding between HST & Power-Reverser
/ Deciding between HST & Power-Reverser #21
Have you seen or checked out these tractors???
willy
I love that transmission in my tractor. You'll never want any other, once you set it up to your liking. I learned really quick with being efficient when I was having to move over 200 IBC totes to process for firewood storage. I have used clutch twice in the 51 hours that I've used it,...and the funniest thing about it, is that I didn't even need to. Other than the questionable steering under load,...it's a great machine.
/ Deciding between HST & Power-Reverser #23
Top speed in 1rst gear on my tractor is a maximum of 1 mph at full throttle.
I run a 6' King Kutter II tiller on my 35HP gear drive and tills great
I used to run a tiller on a gear tractor. It got the job done, but low gear was often still too high. I did a lot of stop/start. With my HST machine I can be nearly stopped and still tilling.
/ Deciding between HST & Power-Reverser #24
Can't say I ever had that issue.
My gear drive runs my tiller just fine.
/ Deciding between HST & Power-Reverser #25
One thing to keep in mind with HST is engine RPM is everything...
Exactly. Operate an HST like you would a Bobcat or an excavator. Really, it's the same principle. You aren't turning a drive train as much as you are powering a hydraulic pump. The only thing that is absolutely engine speed dependent is the PTO speed.
/ Deciding between HST & Power-Reverser #26
I thought I'd want a gear drive after growing up on them on the farm. I test drove a few TYM HST models and was sold. I have a 4-range hydro which gives me indefinite speeds. High range is really transport speed. I generally work in 2-3 ranges. Low range is probably 1/2 mile per hour at PTO speed? It's nuts. The cruise control is nice for field work, as is the auto throttle... I set the throttle to my desired minimum, sort of nice for a unit with DPF, then the engine RPM follows pedal displacement after that. Really nice feature.
/ Deciding between HST & Power-Reverser #27
Thins to consider. A hydro is a hydraulic drive it consists of a pump and a motor. Being a hydraulic unit they take more power and fuel than a gear drive. Since it is a hydraulic drive there is a limit it can work often controlled by a relief valve. If you operate in a higher gear the unit can 'stall', this can be overcome by shifting to a lower gear. A hydro transmission is made of a lot of carefully machined parts. Which means if needing repair they can get expensive. Yes they are handy as they are infinitively variable and easy to shift forward to reverse. More expensive than a gear drive.
A gear drive usually will not fail but may take a clutch replacement, depending on useage. They also provide more power to the wheels and less fuel consumption. Depending on make and model the PTO can be a pain if it is transmission driven. Cheaper than a hydro.
In the end you have to consider what you want out of the tractor, and which option suits your preferences.
So, I have been thouroughly enjoying my 60HP HST tractor. I tilled with it yesterday and did a grand job. Set the cruise control and went nice and slow. Also, being able to just go back and forward while turning in tight spots is nice as well. I am adjusting nicely.
Still hitting the forward pedal like it is a gas pedal on my old gear tractor. LOL. Muscle Memory from years of shuttle shift.
/ Deciding between HST & Power-Reverser #29
never owned HST but sounds like it serves many very well here. after all, this is a compact tractor forum, & HST sounds like a good match for small/mid sized tractor use. there's a reason most larger utility tractors (M series, etc) are gear driven power trains for some of the reasons stated above
driven manuals most all of my life, fortunately no knee etc issues, my hyd shuttle on my 12x gear unit to me is the best of both worlds. (all gears are synchronized)
glad the HST is a good fit for many members here as well, regards
/ Deciding between HST & Power-Reverser #30
We had geared tractors all our life, then graduated to a 12 speed powershift with a creeper range - which I thought was surely the pinnacle of transmission development. But then we got a HST on a new 60 hp tractor and it really is better. It surprised me just how much better it is for close in inching and loader work.
Caveats: HST is happiest having a little more reserve HP than you normally use, and it definitely needs cruise control.
/ Deciding between HST & Power-Reverser #31
Just saw this. I have two New Holland TC's. A 40 and a 45 hp. I find that I have used them for bucket work as much as anything and changing from forward to reverse with the HST is as fast as the thought. No stopping to change gears or moving a lever. Just think "go back" and that's what you are doing. Love it!
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
1999 Toro Groundsmaster 455-D 126in. Mower Commercial Riding Mower (A64194)
1999 Toro...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A64553)
2006 Generac...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
