Gear drive vs hydro
/ Gear drive vs hydro #281
Well that pretty much ends the gear vs hydro argument. If you can work from the bucket WHILE MOVING with and HST, than that's it. Discussion over. HST wins!:D
:mad: ok then, what about wheelies?
/ Gear drive vs hydro #284
I don't know what you guys are getting at but one can be a cunning linguist without being a ladies man.....I'm living proof. Unless I'm not really a cunning linguist either and if that's the case.....well then I'm just sad now. What could be worse? No good with the ladies, no good with the language, and all I have is a sorry old gear tractor. Sigh.
/ Gear drive vs hydro #285
And to add to the Keep It Going List...
HST tractors can't spin their wheels? Is that really true. I don't know why I care :D but I am curious.
Later,
Dan
Feature or handicap ?
/ Gear drive vs hydro #286
but do you have a walther ppk?
soundguy
/ Gear drive vs hydro #287
neither.... it's a limitied situation when this occurs IMHO... though annoying.. and real.
soundguy
/ Gear drive vs hydro #288
Later,
Dan
Not true. Mine could spin the wheels all the time... that's because I had stinking R4's on it. :p
/ Gear drive vs hydro #289
ah ha! ....I sense a new thread or at least a continuation of the the R1 vs R4 thread. So what you are saying is that HST is better than gear and R1 is better than R4. Clearly then an HST with R1's is superior. But, is a gear drive with R1's better than an HST with R4's? I am getting confused. :confused:
/ Gear drive vs hydro #290
No, you have it absolutely correct.:D
/ Gear drive vs hydro #292
Put that identical HST and gear tractor thru the paces for decades.. except.. don't change or even check the oil in them.. add some water and grit...
Can't tell you how many gear trans antiques I've draind the tranny oil on and had 5 gallons of choclate milkshake that had probably been in there 20 years, and smelled like a sealed tomb full of rotting carcasses, and then when i cleaned the bottom of the sump there was an inch of thick gooy gritty gunk in there.... and no filter on this splash lubed system.
Kick that level of care over to an hst.. no new filters.. ever.. no new oil.. low oil.. water in the oil. and a kids playground bucket full of sand in the system... that's pretty much 'standard -noworries mate' package for the average antique gear tractor
soundguy
Good Afternoon Chris,
I had to go back a couple of pages on this thread to find anything close to making any sense :confused: but your few paragraphs are so very true !!! Thats exactly what I found in the transmission and bull gear pans when I redid the Super A ! ;) Then throw in the fact that the darned tractor has been runnin this way for the past 60 years !
That kind of makes a statement to me ! :)
/ Gear drive vs hydro #293
Regardless of tires there will always be a situation where they cannot be spun on any tractor. Universally, to my knowledge, this will happen first with a fluid drive. This is because you dont have a mechanical connection between engine and wheels - the connection passes thru fluid and fluid pressure is limited by a relief valve. So the torque to the wheels is limited by the relief setting and the displacement of the hyd motor being driven and then the final drive [geared] ratio to the wheels. This is the ratio you select when you change ranges.
With an HST, regardless of the relief setting the engine cannot be stalled without abusive operation of the pedal because you are varying the displacement of the hyd pump. Without the relief, infinite forces would be available in any range just by adjusting the pedal, and thereby pump displacement, so the HP driving the pump would deliver whatever pressure required to give the torque needed at the wheels. Of course the pressures would have to be proportionately higher in the higher ranges to get the torque needed at the wheels. Well, darn it anyway, we cant just keep kicking the forces up thruout the powertrain like that. We have to limit each part according to its ability. We limit the pump/motor with a protective relief valve, and we make the gears in the ranges amply strong to take the [thereby limited] hyd motor torque. We adjust the range gear ratios to give usable speed and wheel torque combinations. This part of the hst tractor is exactly analogous to a gear tractor if you recognize that each gear ratio is a range. Not surprisingly, on modern gear tractors, that usually have at least 8gears, the ratios are much more closely spaced thruout a conventional tractor min/max range of travel speed, than they are with hst which has just 2 or 3 gears/ranges to cover the full range of conventional speeds. So you dont find a lo range on an HST as low as 1st on an 8 speed. The hst will go faster in 1 of 3 than the gear in 1 of 8. That means the HST is effectively in a higher gear. And that means that the HST cannot deliver as much torque to the wheels if the relief valve is set safely. To realize this you have to take a close look at the interaction of the engine, pump, relief valve, and motor. The relief has to be set at a level low enuf so that it will relieve if the tractor is stopped dead in a pull. If it didnt something requiring repair would give. The wheels would spin? In lo range maybe, but not in hi. If the relief doesnt give and the wheels dont spin the engine stops dead. This kind of impulse must be prevented. For maximum and "safe" power delivery it is done by setting the relief at a pressure that will stall the full engine power gracefully at full pedal. Somewhat more than full engine torque is being delivered to the pump in this situation. The hyd pressure seen here is as high as it can go in the protected transmission. This pressure defines the max torque available from the motor that is driving the final ratio. Changing the flow with the pedal has only a tiny effect on this torque as the engine bogs. Because of the relief, backing off the pedal to let the engine work easy does only that - the pressure and therefore torque limit at the motor remains the same. That motor is working against a higher speed gear than 1st on the gear tractor. From all this, it follows directly that the HST cannot deliver as much torque to the wheels as the gear. For example - if the HST goes 2mph at full pedal and rpm in lo range, and 1st on the gear goes 1mph topped out, the gear will deliver a little more than twice the wheel torque. [It would be exactly 2x if HST were equally efficient to gear.]
QED:)
larry
/ Gear drive vs hydro #294
Dan, what I think he is suggesting is that if money is the object, instead of buying a Rolls-Royce 45 hp gear tractor for $20,000 you could get a $20,000 45 hp HST Belarus-Renault-Fiat (new European brand collaboration, with Chinese parts assembled in a cave in Ukraine and marketed by Renault-Fiat for the prestige value.)
Of course that makes no sense at all.
Sure it does!! LOL...
/ Gear drive vs hydro #297
I thought the same. They are aimed to the same group who leave all attachments on the tractor, no matter the chore!! :)
That's right. And for sure that's a group that a HP or two won't matter to.
Andy
/ Gear drive vs hydro #298
Andy
or they could be using reverse psychology on us, after all, they need anything and everything to brag about. Every HP could count, especially if you have a BH, FEL, plow, flail attached, and still want to use your MMM to cut the grass!!
/ Gear drive vs hydro #299
Yep.. they may or may not hold up as good as a gear for multi-decades of ideal use.. but throw in decades of abuse. My 46 ford 2n trans had 1.5" of gritty sludge in it.. and oil the consistency of grease with some water on top of it.
Trans still works fine!.. i expect it to go another couple decades now that it has new oil and a clean-er sump. lets see. 62 years so far .. and going...
an hst with 62 years of abuse and no maintenance.. if they can do that.. then they get my seal of approval.. :) ;)
soundguy
/ Gear drive vs hydro #300
Yep..
soundguy
Good Mornin Chris,
Agreed ! :D
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
White 6182 12R Planter (A66285)
White 6182 12R...
