GC2400 Front Drive Leak
   / GC2400 Front Drive Leak #11
I also git rid of the lighter oil and added heavier 90w axle fluid.
This is a misconception.
The hydraulic oil, and the 85w-90 gear oil are about the same viscosity at normal temperatures.
Not enough difference to have any affect on leaks.
Thanks everyone. I will search for the thread with the parts information. I'm going to give it a try myself I think. How long of a job am I looking at here? I'm assuming just a seal can't cost that much and the cost of replacing the fluid. I don't have very long eclip pliers so I guess Ill be getting a set of those as well. Seems to me like a pretty typical place for a 10 year old tractor to start having some leaks.
   / GC2400 Front Drive Leak #13
Took me half a day but im no mechanic. Take your time and dont cut any corners. Watch the hub covers as they are made of aluminum. I used too much pressure on the pinch bar in the pry point on one. They can be stubborn to remove.
   / GC2400 Front Drive Leak #14
Maybe the dealer gave me even thicker oil? I remember it tool a long time to refill it :)
   / GC2400 Front Drive Leak #15
front axle does take a bit to do, pour some in wait a bit for it to level out pour more in. having the air bleeds on each wheel off does help.
edit: fwiw doing it when its not 26F out helps too.
It seems like the most important/ critical tool I will need is a longer set of ering ring pliers. Would anyone that has done this job have a picture of the ones they used? I would like to just order them so I have them ready when I get the time maybe over Christmas break.
   / GC2400 Front Drive Leak #17
Ill take a pic tomorrow...i believe I git this one from Advanced Auto
So the tractor sat for a month and had a little bit of leakage. Checked fluid and added a little. Cleaned the fill plug really good. Used the tractor for a few hours to move a bunch of firewood. Its been sitting for a few days now and has not leaked. I'm holding out that the breather was just plugged.
   / GC2400 Front Drive Leak #19
plugged vent can cause issues.
hopefully all set now.
   / GC2400 Front Drive Leak #20
Just saw a vid the other day, a dude with a GC tractor, talking about the vent holes (hst and the front axle). Regarding the front axle, that vent could get plugged up, so I'd check on that.
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
20357 (A55758)
20357 (A55758)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 Chevy Silverado (A56435)
2020 Chevy...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
