GC 2300 hydraulic issues
   / GC 2300 hydraulic issues
Can't say it's "good," but the MF manual might be your best bet. I got a full set with my 2310 from the dealer when I bought it. I could help with pics of certain sections if you need it.
Thank you for the generous offer any help would be appreciated
Not sure what you mean by, "pulled the cover off the pump".
You mean disassembled the pump? Or, you pulled it from the housing, and inspected the shaft, and transmission gear?
The photo you posted, is labeled invalid.
Just pulled the 4 bolts what holds the back of the pump and that enabled us to pull both gear s on the pump for inspection
This are pictures of the old pump identical to the pump in the massey
I looked at the gear in the transmission with my camera and it is fine
Did not get pics of the gear in it now but looked good
   / GC 2300 hydraulic issues #24
Here's a couple shots of the 3PH lift arm business from the service manual. As usual there aren't a lot of details in the book, but this may help to get you started.
They have you first remove all the sheet metal in the rear, then remove the fuel tank, then remove the "slow return knob" to get at the lift cylinder case, with a caution not to lose the o-ring from the transmission case (#1 in 2nd pic). They also suggest making punch marks on the lift arms to aid in re-assembly (get them in the same position they were in).
Missing in the first pic, #1 is the "Lift Arm," #6 is the "Rod," #7 is the "Piston."
Hope this helps.
Did you get the service manual from the dealer or did you order ???? on line
   / GC 2300 hydraulic issues #26
You know, I don't remember. Probably through the dealer (who's no longer there....).
   / GC 2300 hydraulic issues #28
Got mine from AGCO pubs last month.
Thanks guys !Q!:drink:
   / GC 2300 hydraulic issues #30
Last week I just ordered paper copies of the "Parts Book" for the QH, 2360 SB, 2340 DB, DL100 FEL, and CB05 BH from AGCO Technical Publications.
They have Electronic copies a little cheaper and you can also just view them on the AGCO Parts Book website (search for: DL100, CB05, 2340, 2350).
Here's the Publication #'s for those that are interested:
KC
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52128)
2014 Yale 3 stage...
