Langanobob
Gold Member
- Joined
- Feb 1, 2007
- Messages
- 411
- Location
- Reno, NV
- Tractor
- AC HD6G, Ancient Kubota HK5 Mini Excavator, MF GC1720
I wish I had been paid for all the times I took something apart only to find nothing wrong with it. You sure you’ve for sure identified the problem? Your suggested fix here sounds not so great. What do you mean by the Japanese are not cooperating? AGCO is not a Japanese company and AGCO is responsible for getting the Iseki parts. Sounds like it may be your dealer who is not cooperating. Tried other part sources?
Ok so here is what i plan on doing since the Japanese wont cooperate So I plan on buying a pump from Northern tools and attaching to the front PTO that normally would drive my belly mower .. Would come off the original suction line that goes to the original pump then discharge to the suction of the original pump. Any thoughts or knowledge if this would work ?? basically I would be hooking it in series with the old pump. It would be cheaper and not as hard to install. Thoughts and advice are welcomed !
