GC 2300 hydraulic issues
   / GC 2300 hydraulic issues #1
Fragger
Huffman tx
Gilson 16 hp twin,GC2300/ Mighty Mite
Ok so about year or so ago I replaced the auxillary oil pump and last week the front end loader and the 3 point hitch quit working.:dance1: So I remember the last time the power steering also failed but it is still working so does anyone have any ideas what could be the problem.:confused:
   / GC 2300 hydraulic issues #2
Starting with simple checks-Does this GC2300 have rear auxiliary hydraulics added? Sounds like my GC2410 when I have the ear hydraulic hoses mixed up. Check all of your connectors for debris or ceased check balls.
   / GC 2300 hydraulic issues #3
Check the linkage for the 3pt. control lever that it still connected to the valve. GC2300.jpg
no DMW when I lift the 3 pt handle it does nothing to the actuator i will get some pics tomorrow..Thank you for your responses ;;
no cdaigle it comes out of the rear end.
I was unloading it from the trailer when it failed but cant see what I may have boogered up,,
DMW i do not believe we have the same pump here is a diagram of my GC2300 TRACTOR PRIOR S/N JNA25201 Login
   / GC 2300 hydraulic issues #6
It's the [190] TRANSMISSION - POSITION CONTROL . If you still have hydraulics for the transmission and steering, your pump may be ok. The control valve pictured prioritizes flow. I believe transmission first, steering second, FEL/3pt last. If the linkage from the 3pt handle is not shifting the spool in the control valve, it may be stuck open, draining back to tank, so all pressure to the FEL and 3pt is lost. It's an easy visual check, tractor doesn't have to be on. All it takes is 1 cotter pin to fall out.
edit to include correct diagram. Arrow wasn't positioned correctly.
Man, that would be great !! after talking to couple of mechanics they seem to think my pump dumped on me ..I like your analogy though and when I get it jacked up p I will look into that and keep you updated..
Thank you for your advice and support:tractor:
Thank you guys for your input am just now getting back on this project after injury....
Ok so here is what i plan on doing since the Japanese wont cooperate So I plan on buying a pump from Northern tools and attaching to the front PTO that normally would drive my belly mower .. Would come off the original suction line that goes to the original pump then discharge to the suction of the original pump. Any thoughts or knowledge if this would work ?? basically I would be hooking it in series with the old pump. It would be cheaper and not as hard to install. Thoughts and advice are welcomed !
   / GC 2300 hydraulic issues #10
If the old pump sheared off the drive gear inside the transmission, you still need to do a tear down.
At that point you might as well replace the original parts.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
TMA (A49461)
TMA (A49461)
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
