GC 2300 hydraulic issues
   / GC 2300 hydraulic issues #11
I wish I had been paid for all the times I took something apart only to find nothing wrong with it. You sure you’ve for sure identified the problem? Your suggested fix here sounds not so great. What do you mean by the Japanese are not cooperating? AGCO is not a Japanese company and AGCO is responsible for getting the Iseki parts. Sounds like it may be your dealer who is not cooperating. Tried other part sources?
Ok so here is what i plan on doing since the Japanese wont cooperate So I plan on buying a pump from Northern tools and attaching to the front PTO that normally would drive my belly mower .. Would come off the original suction line that goes to the original pump then discharge to the suction of the original pump. Any thoughts or knowledge if this would work ?? basically I would be hooking it in series with the old pump. It would be cheaper and not as hard to install. Thoughts and advice are welcomed !
ok when I pull the pump shaft I will know if my gear is bad thank you for your responses
ok so yesterday we pulled the cover off the pump and inspected the gears and splines and they looked good unlike the first one .so o
sounds like I may need a service repair manual so I can quit guessing. anyone recommend one
   / GC 2300 hydraulic issues #15
Not sure what you mean by, "pulled the cover off the pump".
You mean disassembled the pump? Or, you pulled it from the housing, and inspected the shaft, and transmission gear?
The photo you posted, is labeled invalid.
Pulled it from the housing and inspected the shaft splines and the gear ll looked good neighbor who is one more French fry closer t o happy meal than me said probably had a stuck relieve valve .
can anyone recommend a good repair manual with diagrams??
   / GC 2300 hydraulic issues #18
Can't say it's "good," but the MF manual might be your best bet. I got a full set with my 2310 from the dealer when I bought it. I could help with pics of certain sections if you need it.
   / GC 2300 hydraulic issues #19
I seriously doubt the existence of any independent versions of a GC2300 repair manual.
The only difference is the price, because of who you get it from, and in what format.
Thanks guys!!! ok it appears to be the 3 pt cylinder seal the tractor will drive I removed all the accessories and pulled the back off the pump; the gears splines and gears looked perfect compared to the last pump I pulled off. the fellow I talked to said if I could lift the3 point with no resistance then my seal was shot so I did and It is .
SO the diagram for the 3 pt cylinder would be appreciated if anyone has a good illustration.
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
New Holland B95 Backhoe (A50490)
New Holland B95...
Online Buyers Premium (A47384)
Online Buyers...
