Gas Shutoff's
/ Gas Shutoff's #31
I do the parking cone funnel at work for the diesel generators… can’t spill a drop because spills trigger reporting and mitigation.
/ Gas Shutoff's #32
Geeze. I recall back in the early 80's sitting at the airport fuel farm at night watching a semi unload jet fuel into the ground tanks. The driver did not stick the tank for volume and just let it flow. He got back into his truck to wait (another no-no). All of a sudden, fuel came shooting out of the vent pipes. Huge spewing fountains. By the time he jumped out and closed the valve on the truck, it took another minute or so to stop spewing out the vents. I'd guess several hundred gallons on the ground.
I reported it to airport security and safety as required. They pretty much came over, looked around, shrugged their shoulders, told him to be more careful, and left! It just soaked into the rocks.
I often wondered how many times stuff like that happened over the decades.
I found an article from 1995 that said they estimated between 20,00 and 40,000 gallons of fuel had been spilled at that tank farm over the years, when they replaced underground tanks with above ground tanks.
/ Gas Shutoff's #33
Once a fuel tank is gummed up from ethanol, how can you clean it out?
That's a common misconception. Ethanol itself does not gum up anything. In fact, it's a cleaner for fuel systems. Most all fuel system "cleaners in a bottle" are alcohol of some kind--Read the SDS. The stronger the alcohol, the stronger the cleaning. Gumming comes from the gasoline by degradation. Varnish, tar and gum are produced by the gasoline, not the ethanol.
Ethanol is bad for old gas systems because it attacks rubber and some gasket materials. It also absorbs water that can rust and corrode old fuel systems with unprotected metal.
Best way to clean a gummed up gas tank is to wash it out with fresh gas or strong solvent. Don't store gas in a machine's gas tank because most are vented and cause the gasoline to degrade.
/ Gas Shutoff's #34
Yeah, StaBil or the like will only extend the time, it's not a cure all. That's mainly the reason I went with the smaller tanks, in theory I will rotate tanks before it gets there.
Another thing to look at is how busy is the gas station, a busy one will be better as it will be refueled way more often than a smaller mom and pop one on the lesser traveled roads.
/ Gas Shutoff's #35
Heyah Tractor folks,
I deal with many chemicals with my job, including Jet fuels.
So here's the deal on Ethanol, as mentioned above it's a damn good solvent and will clean just about anything out of a fuel system besides metal oxides. It's downfall is it pulls in atmospheric humidity and promotes dissimilar metal corrosion and electrolysis. Not good!
How to fix? Absolutely no Ethanol in your fuels... This may be impossible if you live in places like California light - aka Connecticut!
No options for Ethanol free unleaded here .. :-(
So next best is to install a shutoff and run your carbs mostly dry. But the best fix ( no Ethanol ) is to go Racing or Aviation Fuel - but they are not cheap!
So a good alternative is to use a newer product like Ethanol Shield.
This product actually emulsifies and completely suspends water into the fuel. Stabil doesn't, even their marine stuff!
You can also use a DMGE bearing chemical like Prist or Sludge-b-gone and this will keep the water suspended. But it is not a fuel anti-oxident like Ethanol Shield.
Diesel fuel:
I have many diesel powered pieces of equipment, including a F350. So what does an Engineer use?
Cheapest stuff that works:
Biocides and water dispersant:
SBG – Sludge Be Gone | FPPF Chemical
fppf.com fppf.com
SDS:
More expensive version:
Hi-Flash Hi-Flo Anti-Icing Fuel Additive | PRIST Jet Fuel Additives & Aerospace Cleaner Supplier
(May be found for "Free" when idiots place an expiration sticker on bottle. Sorta like trying to argue with Quality Engineering when they place an similar sticker with an expression date on packaged Titanium or Nickel welding wire.....)
Oh BTW this is important!
This crap is transdermally toxic - it will attack your liver if you get it on your skin. Wear gloves and don't be
stupid...
Good luck, Blake
2015 Audi A4 Sedan (A59231)
2015 Audi A4 Sedan...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2019 CATERPILLAR 420F2 IT BACKHOE (A59823)
2019 CATERPILLAR...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
