Diesel mixed with gas
/ Diesel mixed with gas #1
Sean2202
CT
Kubota L305DT
Greetings,
Somone at my work accidently topped off one of the small engines with diesel. I would guess that about 1 gallon of diesel was added to the 7.5 gallon tank. The Diesel gas mixture was removed and the plugs and fuel filter was changed. Fresh fuel was added and the engine runs fine now. A fresh oil change is planned as well. All the machines at my work that are gas have "GAS" written on the caps and all the diesel machines have the fuel caps painted the same color as the pump handle.
So my question is what should be done with the gas diesel mixture?
Sean
How much gasoline was in the tank?
I would guess about 1 gallon of diesel was added to 6 gallons or so of gas to fill the 7.5 gallon tank
Mix it with more gas and use it in an old tractor. Won’t hurt a thing in an old low compression carbureted engine.
Interesting, I was considering adding it to my bulk tank of 300 gallons of gas. However, there are too may vehicles that use it including 2 cycle that could be affected. We don't have any old gas tractors that run low RPM here. How about an old chevy 350 carb engine from the 70's? That old truck has a large tank that could dilute the diesel Possibly.
/ Diesel mixed with gas #5
If it’s an early 70’s with pre smog heads I think it would be just fine. Smog heads were pretty bad about detonation
I doubt 1 gallon mixed with 300 would hurt a thing but????
No smog stuff on it. 76. I don't think it is original to the truck though.
/ Diesel mixed with gas #7
I think you will be fine with this small amount of diesel in a single cylinder gas motor. At worse the plug may need to checked after a few hours if it runs rough. Keep adding gasoline as you burn up the current mix to further dilute the mix.
We did this to a lawn mower once without lasting effects.
/ Diesel mixed with gas #9
if in doubt or if you don't have a old style gas motor you feel comfortable running it through why not dispose of it through local recycling depot?
our local dump takes used old/gas/paints.
In your area a quick google search may give you location to drop it off.
Come to find out they actually ran it for about an hour like this. For clarity its a B&S vanguard 18hp v twin. It ran but not very well. "We just thought it was cold so left the choke on". Next person comes and says, "This isn't running right". Fuel filter had a red tint. Dead give away.
I think I will add it slowly to the old truck. Good to have old stuff around.
Thanks for the posts.
/ Diesel mixed with gas #11
Pipelines routinely send multiple fuels through a pipeline at once such as gasoline of multiple grades, heating oil, aviation fuel and diesel, seperated by plugs. Gasoline is normally clear, with the amber tint coming from small amounts of mixing with diesel or oil. Just saying, gasoline is not pure.
/ Diesel mixed with gas #12
Diesel has a low octane rating.
Some 50’s tractors ran distillate fuel or tractor fuel with an octane of 35-45. They would start on gasoline and get good and hot and switch over to the distillate. Many times the carb had additional heat from the exhaust manifold to help vaporize it.
These engines had a 5:1 to 5.5:1 compression ratio. The same tractor with gasoline only had a 6:1 ratio for the 60 ish octane gasoline at the time. Many later converted the tractors with higher compression pistons or in case of the JD 2 cylinders a higher compression head.
It wasn’t till the early 60’s that they raised the compression ratios further for more power per cubic inch.
For example the AC 226 was the same basic engine from the 1953 WD45 with 6.45:1 till the1980 175 with 8.2:1. There were some camshaft on other minor differences as well
Many tractor pullers would bolt 175 parts into their wd45 boosting HP from 38 to 54 hp
The spark plugs and other components don’t care.
/ Diesel mixed with gas #13
It is time to go out and buy a really old tractor.
I just bought an older John Deere BO Lindeman. I was puzzled a bit by what appeared to be two gas tanks. Not running yet, but I do read. :)
The things were considered multi-fuel.
Hand start them on gasoline. Then once warmed up, switch them over to kerosene. They can apparently run on 100% kerosene. No so happy with 100% diesel, but will take a diesel/gas mix.
Part of what Deere did, and Caterpillar also did something similar was to connect the exhaust and intake manifolds so that the kerosene was preheated to help with vaporization and volatility. I've also heard about preheating the fuel before getting to the carb.
/ Diesel mixed with gas #15
Greetings,
Sean
It makes a great fire starter for burn piles.
/ Diesel mixed with gas #16
With that much gasoline a good way to burn yourself as well like my neighbor did when the vapor ignited . .
/ Diesel mixed with gas #17
I had a tank with really old half varnish gasoline that I used as a fire starter. WHOOSH!!! I agree, be careful with burning gas.
/ Diesel mixed with gas #18
Several have put diesel in gas cars…
None were worse for wear and all 1960’s or older…
Just needed to dilute the diesel enough to get the engine running again.
/ Diesel mixed with gas #19
I wouldn’t throw that ratio of gas on a burn pile. Pouring half of the mix into a gasoline vehicle wouldn’t hurt anything. Or if you have waste oil disposal just pour it in that.
/ Diesel mixed with gas #20
It won't hurt anything if you add it to your 300 gallon bulk tank.
