Garage for Power Trac and Shop
   / Garage for Power Trac and Shop
ksimolo said:
Someone had better not be installing one of these systems just based on these posts - there are lots of obvious things missing! For example, an expansion tank is needed in a closed system, pressure relief valve, possibly air remover/vents, GFI, a way to fill the system, etc.
Ken
Thanks for all the info. I don't plan to use this garage full time. Also I have a heated garage at the house with R50 wall and R55 ceiling insulation. It is where I will do the automobile repair work. The heat floor sounds nice, but money is not unlimited. I think I will stick with the wood stove and maybe propane later when I get tired of wood (if I do). Thanks again, fellows.
   / Garage for Power Trac and Shop #102
Bob, before you completely give up on the dream, you may still want to at least lay in the PEX/ It won't be too expensive and this is the time to do it, even if you do not go for the heater unit.
You probably would get the money you put in out in case you ever sold, and next year when you win the lotto you can hook it up with ease
Carl
Carl
OK. I will discuss it with the builder on Monday and see if I can get a layout from the PEX manufacturer.
   / Garage for Power Trac and Shop #104
Water based radiant ala PEX is not the only way to go. For an occassional use garage, electric based radiant is very viable. Check this site. They even have prices
Heat Under Floors with Heating Cables
   / Garage for Power Trac and Shop #105
Wow - the electric stuff is very expensive! Much more than PEX. I have seen it before but never bothered to look at the price. The electric version is commonly used in bathrooms and sometimes entrance ways/mud rooms. I do know of someone who uses it in their small home.
In-floor heat has a fairly long lag time so if you are only working for an hour or two and you normally have the heat off, it is not a good choice (electric or hot water). As a baseline heat or working all day, it is very nice.
I love throwing my wet gloves, etc. on the floor when i come in from working outside. The next day they are dry and warm, ready to go at it again.
Ken
   / Garage for Power Trac and Shop #106
ksimolo said:
In-floor heat has a fairly long lag time so if you are only working for an hour or two and you normally have the heat off, it is not a good choice ...
That is an excellent point that must be understood by anyone considering this type of heating system.
A few cool things can be done with hot fluid besides heating the garage floor and house. For instance...
Add a loop to the front porch or sidewalk to melt ice. Especially nice if your sidewalks are on the north side of your house in the shade in winter.
Heat your driveway, too, while you're at it.
Add a heat exchanger to heat your pool water in the summer.
   / Garage for Power Trac and Shop #107
What!!! heat your driveway and not get to clean the snow off with the pt, hum I guess if you are in a hurry that would be ok, just joking. The salesman that sold me my wood/coal furnace told me that I could add heating coils in it for liquid rather inexpensively if I wanted to but I didn't feel I needed it. I can add it later if I want to though.
   / Garage for Power Trac and Shop #108
Best of both worlds. Fill the tubing under the driveway with oil and put quick disconnects on the ends. Hook up to PT pto and let the hot fluid flow to melt the snow.
   / Garage for Power Trac and Shop #109
That's a $20,000 boiler ya got there buddy...
Might want to think about something a little cheaper...
Just my $0.02...
All the best,
Peter
Well we started construction this week. We dug and poured the footings in a day and put in the cinder block (was all that this week?) on another day. We are dodging bad weather and it seemed we just snuck in the footings. The blocks were supposed to be installed on Friday, but the mason's crew did not show up. They did come on Saturday and put in all of the blocks they had during a light snow. They ran out and need 32 more. I was happy since the rest of the work is not so dependent upon the weather. The walls look very straight and the builder used 12 inch wide block at the base. This is really not needed here. I guess he wants to do a really good job. It will be very cold on Monday, about 12, so we cannot do work. It's supposed to snow a little on Tuesday, but I hope they will still be able to work. Our snow storms this year have been really just fluries. We put some conduit in for the panel and some others in case I want to add a sink someday. My pictures are too big so I will have to shrink them first.
Edit: Added pictures
No, I did not dig the footings with the Power Trac. The pictured backhoe/loader dug the footings in about one hour and made them really straight. It was so slow because of the mud. It did get stuck, but pulled and pushed itself out with the backhoe. It almost turned over once when a wheel sunk in the mud. I think the Power Trac would just have gotten stuck.
I plan to have two garage doors. One on the front which will be 18 feet wide and one on the side which is 9 feet wide.
This past week we poured the slab, and today we raised the walls. We put almost 100 tons of gravel under the slab. The trusses should be here Monday and they will be installed on Tuesday if things go well.
I marked the locations for the outlets and drilled many holes for wires. Tomorrow I will install the electrical boxes.
Things are going extremely well so far, with the weather being in the 20's at night and 40's during the day with little rain or snow. Last weeked I went to a Black Smith meeting and someone was giving away steel. I got an I beam about 6 feet long. I embedded it in the floor (see attached picture) and will be using it for a vise stand. The Bobcat driver tried to push the I beam into the gravel with no luck. I got the post hole digger and PT422 and drilled the hole in about 30 seconds.
I forgot to take pictures of the walls, but will do so tomorrow.
   / Garage for Power Trac and Shop #113
Very nice work Bob, looking real good
Thanks MrJimi. I took some pictures of the framing today. See attached. I put in all of the switch and outlet boxes that I could today. No big deal, but it's one more thing done.
   / Garage for Power Trac and Shop #115
wow! ... That's a good lookin' project! ... Thanks for sharing the pictures.
Have you settled the lighting question yet?
I am putting in 15 fixtures with 2 four foot tubes each. The bulbs are the T8 (1 inch in diameter). I will have five light switches, each controling three fixtures. If this is not enough I will have a halogen light on a stand.
We are making good progress. Yesterday and today they put on about 80% of the shingles. The pictures were taken early in the day and by 5 most of the shingles were on. We had the framing and electrical inspection today and everything passed except the ground rods. I had not installed them since the builder wanted to wait until we had graded the ground. The inspecter passed the electrical once he saw me starting to install the rods. I have attached a few pictures.
   / Garage for Power Trac and Shop #118
Looks nice. I have to ask... why are they installing the shingles from the top down? :confused:
   / Garage for Power Trac and Shop #119
Great looking garage/shop !. I too wondered why the shingles are being installed from the top down. :confused: Should this thread be moved over to the Projects Forum ?
As far as the roof, I too questioned this. What he is doing is dividing the roof into four sections from top to bottom. He does the top section. Then the next section and lifts shingles to join the two. The advantages is that he never (or rarely) walks on a finished roof section. Also the 2 X4s to aid in moving around on the roof (it has a 10/12 pitch) are not nailed into shingles, so there are no holes to patch in the shingles. Overall I think this will improve the job. There will be much less damage to the shingles when the job is done.
Should this be in the project forum. I don't know. Probably yes. I would prefer it here since this is my home. Maybe I should include more pictures of the PT. I have used it to tow a trailer of electrical supplies and move the wood stove around. Also carry trash out to the street.
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
1981 Kari Kool CTK 6,500 Gallon T/A Tanker Trailer (A59230)
1981 Kari Kool CTK...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
