Fuel pump
/ Fuel pump #1
walker45
I have a Branson 4220 my low pressure fuel pump went bad trying to find a replacement some have said to go to NAPA and get one but I can't find the correct pressure for the pump I see several but they have differant psi ratings. I have no local dealer and to ship it is high so if someone knows the specs of this pump please help it is located on the firewall and lifts fuel from tank to filter
/ Fuel pump #2
Hello. Several threads out there on this already. A unit for a 4 cylinder engine should suffice. Suggestion- put a pre-filter inline to the new pump.
/ Fuel pump #4
I got this one on Amazon for $10.84. https://smile.amazon.com/gp/product/B00L8IHM9K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Been running flawlessly for three years.
/ Fuel pump #5
you can use just about any type of fuel lift pump, but you want to stay with in 4-7psi, as long as you stay in this range you can use just about any lift pump out there.
/ Fuel pump #6
Asteral is right. I replaced my fuel pump with a 7psi one from Napa several years ago. it was on a 2004 Century 2535 (Branson 3510). It has worked fine since. W. Jones
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2007 JOHN DEERE 120C EXAVATOR (A65056)
2007 JOHN DEERE...
KOMATSU D155AX-3 Final Drive (A68134)
KOMATSU D155AX-3...
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
PORTA POTTY (A67714)
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
