Fuel pump
/ Fuel pump #1
walker45
I have a Branson 4220 my low pressure fuel pump went bad trying to find a replacement some have said to go to NAPA and get one but I can't find the correct pressure for the pump I see several but they have differant psi ratings. I have no local dealer and to ship it is high so if someone knows the specs of this pump please help it is located on the firewall and lifts fuel from tank to filter
/ Fuel pump #2
Hello. Several threads out there on this already. A unit for a 4 cylinder engine should suffice. Suggestion- put a pre-filter inline to the new pump.
/ Fuel pump #4
I got this one on Amazon for $10.84. https://smile.amazon.com/gp/product/B00L8IHM9K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Been running flawlessly for three years.
/ Fuel pump #5
you can use just about any type of fuel lift pump, but you want to stay with in 4-7psi, as long as you stay in this range you can use just about any lift pump out there.
/ Fuel pump #6
Asteral is right. I replaced my fuel pump with a 7psi one from Napa several years ago. it was on a 2004 Century 2535 (Branson 3510). It has worked fine since. W. Jones
Attention (A57148)
Attention (A57148)
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2012 Ford F-250 4x4 Pickup Truck (A60352)
2012 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
