Oil & Fuel fuel gauges
/ fuel gauges #1
kokopelli2
central maryland
kubota/b2910
hey guys does anyone else out there have a faulty fuel gauge on their b2410? if mine reads 1/2 it ir really empty! i found this out the hard way. the gauge goes way past full when full.
steve
/ fuel gauges #3
The fuel gauge on my B2410 appears to be functioning normally. It does go slightly over the full mark when I fill it up, but the "empty" side of things seems fairly accurate. I haven't let it get much lower than 1/8 of a tank but I was still going strong at that point.
Kevin
/ fuel gauges #4
I have the best guage on my L3000, it always reads "Full" so its ready cheap to run /w3tcompact/icons/smile.gif
Mark
/ fuel gauges #5
The fuel gauge on my B2410 acts like GlueGuy has described. I have run it down nearly to the 'E' line without running out of fuel.
Rob
/ fuel gauges #7
My B2710 works about like our cars; takes quite awhile to come off the full mark, then the lower it gets the faster it falls, been down to less than 1/8 and haven't run out yet.
Bird
/ fuel gauges #8
My guage belongs in the fiction section. read 3/4 full and yet it took almost 5 gallons!
Rogue
/ fuel gauges #9
L4610 fuel gauge is in the fiction section as well. Definitely non-linear. Haven't run it dry but have run it below the little red empty line. Even then it didn't hold the volume advertised for the tank. Assuming Kubota got the liters/galons thing right then the gauge is a bit of an alarmist but better this way than running dry with a quarter showing. I think my Kubota is still more accurate than my Ram 3500 before or after the dealer replaced the sender under warranty.
Patrick
/ fuel gauges #10
My fuel guage seemed to be working fine until I got stuck down on the river bank. It sat their nose first at about a 30 degree angle for about 1/2 hour. (the tank was about 1/3 full at the time.)
After I got it winched out, I noticed the guage said it was empty. Thought I had a fuel leak but thanks to that Big Gulp gas cap I could see it was not empty.
Two days later it still read empty and after hearing horror stories about running out of fuel I decided not to press my luck and filled it up to the brim.
Well what do you know the fuel guage started working again.
I figured that some how when it was nosed into the river bed the float must have become lodged.
I guess that was the one way it could tell me enough was enough.
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
/ fuel gauges #11
Yo, woodstock! Nothing like a little Manitoban luck, hay! (my best attempt at speaking manitoban, allthough similar to Saskatchewaneese there are significant differences)
I was afraid it was going to be a fuel logged (like water logged) float or a float with a hole that filled up due to unusual nose low attitude. Relieved at happy ending.
Paktrick
Metaltech Climb and Go (A64553)
Metaltech Climb...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
213138 (A64276)
213138 (A64276)
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
9008SFL (A64556)
9008SFL (A64556)
