Oil & Fuel fuel filter
/ fuel filter #1
silverdollar6
Finger,Tn
ym1610d
I went out to change the fuel filter today and had to use a big pair of channel locks to get the top lock ring loose, is it supposed to be that tight?
/ fuel filter #2
Off the top of my head, I'd say no. Of course, it should be tight enough to prevent leaking and keep it from coming loose due to vibration. In my limited experience, you can get that with a good, firm hand tightness - assuming it's located such that you can get a good grip. If you need more than that, it may mean the o-ring or sealing surface is deformed or otherwise damaged.
/ fuel filter #3
Hand tight works for me.
Bruce
/ fuel filter #4
If you tighten that ring to much you are at risk of cracking the plastic bowl. I would say as tight as you can by hand should be good.
/ fuel filter #6
Sometimes if you don't use a new O-ring or don't use the correct O-ring it will leak unless you get it very tight.
Danny
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
2009 PETERBILT 365(INOPERABLE) (A67714)
2009 PETERBILT...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
3268 (A63117)
3268 (A63117)
