fuel filter relocation question
   / fuel filter relocation question #1
yanmars
Veteran Member
My old fuel filter was located low and underneath the tractor by the factory. It was so vulnerable I tore it off at least 3 times when bushhogging areas where there were hidden limbs etc.
I asked the shop to either relocate it or place a guard cage around it to protect it. They placed it under the hood in front of and at the top of the radiator. My brand tractor had some of the models have the fuel filter placed behind the cab high and near the fuel fill location and I mentioned that but apparently that was not a good option. My tractor has a tendency to run warm so I have both side cowlings off. Still can get pretty warm at times.
It certainly is in a safer place but I wonder if the heat in summer will warm the diesel fuel enough to cause any issues. In the old days of gas engines heat soak could cause vapor lock on with mechanical fuel pumps. Not sure if the diesel pump fuel systems have no heat issues.
Hope it works as it was a $600 project with a new filter and labor. Thoughts or comments.
This may make a difference. The factory fuel filter has a glass/plastic bowl of perhaps 1/2 pint. The new fuel filter is metal and holds at least a quart I would say or 4 times the capacity so perhaps that will keep it cooler. Fuel flow at full power is now much more that 1 gallon per hour on this 45 HP tractor so perhaps there is enough fuel going through that that the diesel fuel will not get too hot. Might be of limited benefit in the winter once the tractor starts in the cold and warms up some but I use it little then.
   / fuel filter relocation question #2
If I was you, I would have totally deleted the stock filter and replaced it with a Racor fuel filter with a 10 micron spin on fuel filter that comes with a clear bottom bowl and drain as well and you could have located it anywhere convenient to your needs. The Racor, while not overly expensive is much less than what you did and it filters much better than your stock filter ever could plus the Racor will separate out any water in the fuel and deposit it in the clear bowl to be drained off.
The stock filter was removed. Just curious if the new location will cause any heat soak problems etc.
   / fuel filter relocation question #4
If in front of the radiator will the ambient air be drawn across the filter helping pull heat away? I doubt will be concern with diesel fuel vapor lock but I could be proven wrong.
   / fuel filter relocation question #6
Does your tractor have a lift pump before the filter? Vapor lock with gasoline and mechanical pumps was caused by the suction boiling the fuel. That is why adding an electric pump to feed the mechanical pump would solve the problem.
Most diesel engines have a lift pump, which sets low enough to get gravity fed fuel from the tank and "lifts" it to the injection pump, so there is always fuel at the injection pump which runs at a much higher pressure. Diesel has a lower vapor pressure, and higher boiling point than gasoline, so it isn't prone to vapor locking. Particularly if there is pressure from a lift pump on it.
1605 (A57192)
1605 (A57192)
THREE POINT ATTACHMENT (A58214)
THREE POINT...
Kubota L4701 (A53317)
Sedan (A59231)
Sedan (A59231)
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
golf cart (A56859)
golf cart (A56859)
