Fuel Additives
/ Fuel Additives #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
What fuel additives do you use in diesel fuel, I always used them in my Kubota, JD, and in my diesel pick-up,
Anyway my JD I have now has a DPF and I wonder if I can use anything without damaging the DPF?
Also read some guy's are using 2 cycle oil
/ Fuel Additives #4
I use Fuel Doctors: Fuel Doctors | Your Complete Fuel System Conditioner Injector Cleaner I don't know if it's available in your part of the world but the world is a smaller place with the intertubes.
This stuff is used in all diesel tanks, including the big ones for home generators. It saved my 4105 when I had a nasty biological growth in the tank... broke down the 'nasties' to the point where I didn't even have to replace the fuel filter! :eek:ath:
I add 50ml to every 20ltr 'can' of diesel I get.
/ Fuel Additives
Looks like some good stuff, but I don't find it for sale in the USA
/ Fuel Additives #6
JD sells winter and summer blended diesel fuel treatment. It is very inexpensive. Like $7.00 for a bottle that treats 52 gallons (winter blend). If in doubt, use the JD stuff in your JD machine.
/ Fuel Additives
Thanks, wasn't aware JD had this.
/ Fuel Additives #8
Sta-Bil in tractor and Stanadyne in Duramax truck.
/ Fuel Additives #11
/ Fuel Additives #12
Power Service White bottle, summer and winter...for the last 10+ years
/ Fuel Additives #13
Why bother with lotions, potions , magic and sorcery?
/ Fuel Additives #15
I tend to agree that the additives are just that.. no way to prove that any of them really work as advertised or that they are necessary.
/ Fuel Additives #16
Anyone up North that has experienced a gelled diesel due to poor winter blend fuel might tend to lean towards the additive camp. I blend my own #1 and #2 50% at the off-road pump so I know for a fact I'm getting true winter blend. Then I also add a winter anti-gel/cetane booster so I know for a fact on a zero degree day I won't have trouble plowing snow. I did my stint with a tarp and torpedo heater trying to thaw a gelled tractor once, never again. 4 ounces of prevention is way easier:)
/ Fuel Additives #17
Bingo..
/ Fuel Additives #18
Yes, wait unit you have some algae growing in your fuel and you'll quickly find "lotions, potions , magic and sorcery" are simple time saving problem solvers.
/ Fuel Additives #19
Why not just run straight #1 diesel and not have to worry about paraffin wax ? The only additive to consider would be isopropyl alcohol to “absorb” water .
/ Fuel Additives #20
Never seen algae here. Tanks are indoors in the shade . Plus enough fuel is rotated through to keep it fresh.
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
60� Tine Rake (A64047)
60� Tine Rake...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
