Fuel Additives
/ Fuel Additives #11
/ Fuel Additives #12
Power Service White bottle, summer and winter...for the last 10+ years
/ Fuel Additives #13
What fuel additives do you use in diesel fuel, I always used them in my Kubota, JD, and in my diesel pick-up,
Anyway my JD I have now has a DPF and I wonder if I can use anything without damaging the DPF?
Also read some guy's are using 2 cycle oil
Why bother with lotions, potions , magic and sorcery?
/ Fuel Additives #15
I tend to agree that the additives are just that.. no way to prove that any of them really work as advertised or that they are necessary.
/ Fuel Additives #16
Anyone up North that has experienced a gelled diesel due to poor winter blend fuel might tend to lean towards the additive camp. I blend my own #1 and #2 50% at the off-road pump so I know for a fact I'm getting true winter blend. Then I also add a winter anti-gel/cetane booster so I know for a fact on a zero degree day I won't have trouble plowing snow. I did my stint with a tarp and torpedo heater trying to thaw a gelled tractor once, never again. 4 ounces of prevention is way easier:)
/ Fuel Additives #17
Bingo..
/ Fuel Additives #18
Yes, wait unit you have some algae growing in your fuel and you'll quickly find "lotions, potions , magic and sorcery" are simple time saving problem solvers.
/ Fuel Additives #19
Why not just run straight #1 diesel and not have to worry about paraffin wax ? The only additive to consider would be isopropyl alcohol to “absorb” water .
/ Fuel Additives #20
Never seen algae here. Tanks are indoors in the shade . Plus enough fuel is rotated through to keep it fresh.
2023 CATERPILLAR 279D3 SKID STEER (A62129)
2023 CATERPILLAR...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
Giyi BF47 Quick Attach Hay Spear (A60463)
Giyi BF47 Quick...
John Deere 5300 (A60462)
John Deere 5300...
