FUEL ADDITIVE
/ FUEL ADDITIVE #22
Any additive that contains Methyl or Ethyl Alcohol will ruined a DI gasoline or diesel injection system. The only "safe" de-icer" is IPA isopropyl Alcohol, in small doses.
Had to get a jug and read the label. Not sure what Power Service uses. I guess it really doesn't matter to me. I have 5 diesel engines and they all drink it.
Sorry, I'm not smart enough to rotate the pic.
/ FUEL ADDITIVE #23
I've said it on this forum before and I'll say it again, Power Service ate one of my injection pumps...
It goes below 0F here every winter and I don't use any witch craft products, I just buy good fuel in the first place and I don't have any fuel problems at all!
SR
I agree 110%.
Put diesel in your fuel tank nothing more. Buy good winter fuel for winter. It has been -21 here this winter and I致e had no problem with my tractor. Winter fuel is already cut and ready for your localized temps, no need to put more crap in it!
/ FUEL ADDITIVE #24
That's odd that you know certainly that Power Service ate an injection pump but yet my 18 year old 240K mile truck has drank it every year with no problems. :confused3:
"I" didn't know, but my injection pump guy opened it up, first thing he said was, "you been using power service".
SO, a guy that rebuilds pumps for living knew!!
SR
/ FUEL ADDITIVE #25
I agree 110%.
No argument here. Just telling you that's not true in my locale. My Son works for a Tow Service. When temps get close to zero and/or below 95% of their business is gelled diesels. An Interstate hiway runs thru our County. A sizable percentage of those tows are trucks off that hiway. So obviously it's not just my little piece of Missouri that is selling fuel that's not properly treated.
/ FUEL ADDITIVE #26
I agree 110%.
Coldest it had got here this winter so far is, -4F...
I put some fuel in a jar and had it outside in that -4 and it never clouded a bit...
NO witch craft needed!
SR
/ FUEL ADDITIVE #27
SR
That's what the "pump guy" here says but he says "Howell's". :)
/ FUEL ADDITIVE #29
Sounds like a good place to be FROM!!
SR
/ FUEL ADDITIVE #31
Cummins recommends Power Service black label [ actually says ' Endorsed By ' ].... Good 'nuf fer me and any of my diesel drinking beasts.... To each his own, just like oils, and greases, and women......
/ FUEL ADDITIVE #32
I agree 110%.
Been quite a few people not that lucky, I blend my own fuel in my bulk tanks, I have a winter and a summer tank, the winter tank is blended #2 and #1 about 50/50 with the standard dose of Powerserve, when we got the cold weather this winter it got an additional dose into the tank when I fueled up. This is about the same procedure that most of my neighbors do and all the farmers do, do have one neighbor that didn't helped tow and push his tractor into a shop where he could warm it up and fight with it. So you all do what you want but quite often diesel will need to have additives and or dilution.
One more thing there is no way I would carry 5 gallon cans from town to fill my tractors.
/ FUEL ADDITIVE #33
I run a township road grader. Usually I blend the storage tank for Winter use just as you do. That's been the most dependable and easiest. Only time I am not completely satisfied is if I get a hard pushing snow. I can feel the power loss with the blended fuel. But it's considerably more powerful than the machine with a gelled tank of fuel. :D
/ FUEL ADDITIVE #34
Around here........suburbia KC KS.....the very busy stations say #2 diesel year 'round. The times that I have asked an attendant about the #1 change over, he didn't have a clue if there is a change over. Maybe very rural and more urban folks are treated differently around here....or around the country for that matter.
And, the home owner, small acreage users (5 gallon folks) have a problem turning over (storage) the fuel based on what the season brings. Most of their other "chore" are quite variable I'd imagine.
Peace be with you.
Mike
/ FUEL ADDITIVE #36
How much should I be using and what about howes
You should use any additive as prescribed on the container.
Many farmers I know use Howes.
/ FUEL ADDITIVE #37
i had trouble the firstyear i owned my diesel. since then use the antigel. however - still cannot start it even with a magnetic heater installed and plugged in for days. so i am stuck as to good or bad to use stuff. it doesn;t seem to help me get it started when i need it for snow. so -
i se major league big time diesel earth moving equipment sit parked for days in cold and overnight etc. starts up in the morning and they do not use any heaters that i know of so go figure.
/ FUEL ADDITIVE #38
I don't know technically why some engines start easily, some do not.
I was visiting with a friend of mine about purchasing a CAT backhoe. He asked me what model it was and I told him. He said "don't walk away, run away". Said he used to have one. If the temps were in the teens or below it would take half a day to get it started. Was so bad they would leave it idling all night so they could work the next day. Said he put two engine block heaters on it and still was hard to start. :confused3:
/ FUEL ADDITIVE #39
When I was working the oilfield, we used weed burners to apply heat on the oil pan. Plus a touch of starting fluid when cranking them over. They would never start without the heat.
/ FUEL ADDITIVE #40
just give it a little sniff it will start
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
