Front Wheel Drive not working on FX265D
   / Front Wheel Drive not working on FX265D #1
EricM
Indio, California
Yanmar YM2000,FX265D,YM3110D
On my Yanmar FX265D, the front wheel drive is not working correctly. When you engage it (confirmed) with the double lever, the front wheels will turn slowly, but there is no torque. With the tractor on jacks, with engine on, and front wheel drive engaged, you can stop the tires from spinning with you hand. With engine off, and in gear still, you can sping the tires freely. Front drive shaft moves also If in sand, or mud, with FWD engaged, rear tires spin and front tires do not.
I was told there may be a shear pin that broke, but do no see one on the diagram that Aaron from Hoye faxed. Any ideas guys (or gals)...Thanks.
   / Front Wheel Drive not working on FX265D #2
If the front drive shaft is moving, but the wheels aren't, then either the shaft is spinning somewhere, or you have a problem in the differential. I have heard of a few cases where the bolts holding the ring gear backed out and caused similar problems.
I don't think you are going to diagnose the problem without disassembly. If you have the parts diagram - it should serve as a guide. Just go slowly and carefully. These tractors are really pretty simple mechanically.
CAT 930M (A58214)
CAT 930M (A58214)
Forklift (A59228)
Forklift (A59228)
Massey Ferguson 9250 (A56438)
Massey Ferguson...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
