Front tire sealant
/ Front tire sealant #21
I had one front tire that kept going flat so I foamed them. Killed two birds with one stone. And Pete's Tire Barn even picked them up and dropped them off for no extra charge :)
Did they ship them somewhere? Not certain many folks live near Pete's Tire Barn.
Thanks everyone
If there are no briars, thorns, nails etc. in the tire, an old-fashioned inner tube is hard to beat.
Too much honey locust and mesquite
/ Front tire sealant #24
I have a front tire on my Kubota MX5400 leaking. Any recommendations on tire sealants thanks
Take it to a tire shop. Fix the leak. Install a tube if necessary. DO NOT put any type of sealant inside unless you completely Foam Fill the tire.
/ Front tire sealant #25
I hear people who like the foam filled tires, I have only experienced one tractor with foam filled tires. It was more then enough to convince me to never use them on a tractor, maybe on a lawn mower or a wheel barrow but not a tractor. They lost any semblance of absorbing a bump as well as considerable traction lose.
Also I have nothing against tire sealants, I'd rather see a tire patched well but some sealants will do a good job and save quite a bit of money and time.
I'll do sealants a long time before I'd even look at foamed tires, but that is just me and what I have seen and experienced.
/ Front tire sealant #26
Ya, they make the ride rough and you can't adjust them.
/ Front tire sealant #27
If you want to use sealant, liquid laundry starch works well. I use it it my riding mower tires that pick up a lot puncture vines. I would find the leak first then decide how to repair it. It might be better to repair with a patch or a tube. sealants don't work well on tire beads, valve stems and larger holes. I got a nail in a rear tire of my Kubota , I put a plug in it as a temporary repair , that was 20 years ago. It doesn't leak, every time I would look at it I would think I need to patch that, now the tires are worn out and need to be replaced.
What's a "larger" hole?
TireJect will easily plug a quarter inch hole.
SR
/ Front tire sealant #28
When I had tires foam filled there were 3 choices for density..
/ Front tire sealant #29
I've had good luck with the Gemplers products;
Flat Tire Prevention
My last slow leakers (this summer) i'm trying this; it's working good so far;
Amazon.com
I’ll echo LouNY on the sealant carried by Gemplers. The manufacturer is ULTRASEAL and they make 3 different versions, depending on intended use. You can buy any version/quantity direct, too.
Ultraseal is the fill employed in Humvees if that’s any endorsement. I used it in my PowerTrac and also use the road version of Ultraseal in all the tires of our trailers. Huge peace of mind that I won’t be dealing w a flat in the middle of nowhere or worse. The road version of Ultraseal is also ok to use in tires w TPMS.
/ Front tire sealant #30
They may be hard to beat, but they're also a pain to install. And if there's any slippage between the tire and wheel, at a minimum the tire's outer bead needs to be broken and the tube rotated to match the hole in the rim again.
Just the other day I had a worst case example, where the valve stem had disappeared into the hole. With air in the tube it was easier said than done to break the outer bead and then fish the stem out.
I dislike tire tubes so much that I've made wire wheels airtight (not all that easy) just so they didn't need to have tubes in them.
/ Front tire sealant #31
Point is, I'd use a tire sealant long before going to a foam filled. Once you've done foam, its really hard to change out and you lost any adjustment.
/ Front tire sealant #32
take it off and patch it OR put a tube in it!!!! simple and problem solved!!
This is the only right answer. Take it off and put vulcanizing patch on. Anything else and you be will doing something again with tire until it's fixed right.
/ Front tire sealant #33
But some folks work in cactus or other thorns and flats are not avoidable. When I lived out west folks there doped there tires with sealant. That was what you had to do there.
/ Front tire sealant #35
Tireject. Out in the desert of AZ thorns from cactus and mesquite are just something that are there. Patching and plugging only stops the leak for a short time until the next thorn. Before tireject I spent more time repairing tires than I did running them on equipment. Tireject has changed that. My 2 cents
/ Front tire sealant #36
Yes it is really easy to beat, inner-tubes are now running over $40USD. A bottle of FlatOut is only $16 and can do 4-tires !
/ Front tire sealant #37
Tire Ject it IS absolutely the best, it works the best and it won't rot your rims like slime.
SR
He is right. Been using tireject for years and is great. Had trailer tires that leaked down every week or so put tireject in them and they are still standing and holding steady. Cheaper than paying $20 dollars to the tire place to fix a flat. Use it on lawnmowers, wheelbarrows hand trucks and anything that will hold air. Including basketballs.
/ Front tire sealant #38
I can not imagine that Kevlar fibers are any better than others as a coagulant.
No sense falling for hype!
/ Front tire sealant #39
For my two cent's worth (which may be overpriced): I haven't had need for a sealant on my tractor tires, but I used it on some auto/truck tires, and it's one of the only times anybody remembers hearing experienced, easygoing tow man and mechanic Ed lose his cool and swear like a sailor possessed when he was removing and then mounting a new tire on rim for me. Guys still kid him about it. Another time, I had a local place put a new tire on rim of a small mower tractor, and when they found sealant in the tire, they charged me extra. ~Lefty
2022 EZ-GO ELITE...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2022 EZ-GO ELITE...
