Front tire sealant
/ Front tire sealant #1
Aggie66
Rockdale TX
MX 5400
I have a front tire on my Kubota MX5400 leaking. Any recommendations on tire sealants thanks
/ Front tire sealant #2
Well, I wouldn't put slime in it! On tractor tires that are too old around here, I fill them with water and keep using them.
Note: It doesn't freeze hard enough to freeze a tire full of water, and if it gets that cold, I probably won't be out there on the tractor, so it negates some of the reasons "not" to do this.
David from jax
/ Front tire sealant #7
I'm going on 6 years using FlatOut by Multi-Seal, the same company sealant for semi-truck fleet tires and the military. Sealant good for 10+ years.
This is liquid Kevlar. FlatOut will take care of punctures up 1/2-inch.
This is NOT the flammable green slim junk that lasts maybe 2 years.
Many of the Deere and Yanmar owners on the YTOG use this now.
My place has locust trees. Mowing a pasture is like driving on sharp 2-inch nails. This is the only product I know of to keep my tires going. I've patch punctures at 5/8-inch too.
/ Front tire sealant #10
I’m an outlier because I slimed my Kubota fronts about 20 years ago after always having to add air and that took care of it.
The rears are foam filled do never going flat!
/ Front tire sealant #11
I believe slim is water based and h2o does work it's way out. So I must ask, what are those other brands based with?
/ Front tire sealant #12
Another vote for Tire Ject.
It has stopped several tires (and a couple of wheels) from leaking slowly, the only product I've tried that really did work.
Although, I'm willing to try that Flat Out stuff.
/ Front tire sealant #13
Don't use Slime!!! It's a heck of a mess when you do put a tube in later.
I had a lawn tractor tire blow up with slime in it... started to swell up, middle of the night the tire exploded. Looked like a scene from Ghostbuster's...
Fix the tire right the first time!
/ Front tire sealant #15
Well… it is called slime.
/ Front tire sealant #16
I 2nd the Flat Out. Stuff has been a miracle for use around here. Not one flat after install when I was fixing one just about every time I took any machine out.
They make some for filled tires as well called 'Hydro 1500' that I have in my rears:
/ Front tire sealant #20
I had one front tire that kept going flat so I foamed them. Killed two birds with one stone. And Pete's Tire Barn even picked them up and dropped them off for no extra charge :)
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
Bush Hog 13414 (A64126)
Bush Hog 13414...
We do NOT accept credit cards as payment. (A64127)
We do NOT accept...
Volvo Water Truck, 3306 Cat Engine (A62679)
Volvo Water Truck...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
