Front tire sealant
/ Front tire sealant #1
Aggie66
Rockdale TX
MX 5400
I have a front tire on my Kubota MX5400 leaking. Any recommendations on tire sealants thanks
/ Front tire sealant #2
Well, I wouldn't put slime in it! On tractor tires that are too old around here, I fill them with water and keep using them.
Note: It doesn't freeze hard enough to freeze a tire full of water, and if it gets that cold, I probably won't be out there on the tractor, so it negates some of the reasons "not" to do this.
David from jax
/ Front tire sealant #7
I'm going on 6 years using FlatOut by Multi-Seal, the same company sealant for semi-truck fleet tires and the military. Sealant good for 10+ years.
This is liquid Kevlar. FlatOut will take care of punctures up 1/2-inch.
This is NOT the flammable green slim junk that lasts maybe 2 years.
Many of the Deere and Yanmar owners on the YTOG use this now.
My place has locust trees. Mowing a pasture is like driving on sharp 2-inch nails. This is the only product I know of to keep my tires going. I've patch punctures at 5/8-inch too.
/ Front tire sealant #10
I’m an outlier because I slimed my Kubota fronts about 20 years ago after always having to add air and that took care of it.
The rears are foam filled do never going flat!
/ Front tire sealant #11
I believe slim is water based and h2o does work it's way out. So I must ask, what are those other brands based with?
/ Front tire sealant #12
Another vote for Tire Ject.
It has stopped several tires (and a couple of wheels) from leaking slowly, the only product I've tried that really did work.
Although, I'm willing to try that Flat Out stuff.
/ Front tire sealant #13
Don't use Slime!!! It's a heck of a mess when you do put a tube in later.
I had a lawn tractor tire blow up with slime in it... started to swell up, middle of the night the tire exploded. Looked like a scene from Ghostbuster's...
Fix the tire right the first time!
/ Front tire sealant #15
Well… it is called slime.
/ Front tire sealant #16
I 2nd the Flat Out. Stuff has been a miracle for use around here. Not one flat after install when I was fixing one just about every time I took any machine out.
They make some for filled tires as well called 'Hydro 1500' that I have in my rears:
/ Front tire sealant #20
I had one front tire that kept going flat so I foamed them. Killed two birds with one stone. And Pete's Tire Barn even picked them up and dropped them off for no extra charge :)
