Tire Sealant for Slow Leak
   / Tire Sealant for Slow Leak #21
OKO
Originally developed in the UK.
I have used it in England and here in NZ.
Local website says:
"The OKO Group has been selling Tyre Sealant products in the International market place for decades. The original UK founders still control the OKO business today. OKO was the first effective modern-day Tyre Sealant, and it remains the worldwide technical and market leader."
I presume you can source it in USA ?
Our local website
OKO (NZ)
Try Google for USA/CAN contacts.
   / Tire Sealant for Slow Leak #22
I have a LS GS3038 with 12.4-24 rear tires. The tire pressure goes from 25 to 0 psi in a week. Are the run of the mill tire sealants like "Slime" good for a tractor tire of this size? I assume a gallon per tire might be required.
Alternative to Slime. Gemplers dot com and search for tire sealants. Ultraseal Commercial Tire Sealant -- copy and paste. They have lots of tire problem solutions and the UPS truck saves a trip to town.
I've done business with them since 1986. They have a excellent rust converter that I've used over the years. I wish they had a store in KY!
   / Tire Sealant for Slow Leak #23
First thing to do is find the leak. Then you can formulate a plan for sealing it. Spray bottle with diluted dish soap is effective.
Chris
   / Tire Sealant for Slow Leak #24
Tire sealants ruins the rim. It creates rust and when you replace the tire you will spend hours cleaning it off and removing the rust. Then you’ll need to repaint the rim. Better to repair or replace the tire.
   / Tire Sealant for Slow Leak #25
My "two cents worth" -- with 3 SXS's, 2 4-wheelers, a Kubota B20 and 5 trailers {3 double axle} as well as two riding mowers and a Gravely Zero -- I am used to flat, leaking tires.
On the trailers {as well as my wife's Suburban and my Yukon XL Denali} I use the red rope plugs I get from an auto parts store {I cut them in half as they are WAY too long} and most of those repairs are usually caused by a screw, bolt etc.
After trying just about every "fix-a-flat" made to man and the pricing getting so high, I decided to invent my own! {I also find that "Green Slime" will rust out the steel wheels over time which meant I'd have to weld wheels where the holes had "rotted through"}
THEN I remembered something I did around 1971 while living in ILL with a 7HP Massey riding mower that would lose traction on my yard which was not level. I used a 50/50 mixture of anti-freeze/water and all but filled the back tires.
Sure helped with traction, no freezing, no rotted wheels.
I moved that mower with me to AR in 1974 and used it for several years mowing 2 acres and then moving small trailers when I started my asphalt sealing business in '79.
I had to break down one wheel once {don't remember why -- and I'm not that old!} -- no rust/corrosion/damage to tire OR wheel!
I sold the Massey in/around 1989 with no tire/wheel issues after 18+ years!
SO -- last year I thought -- most all of these "fix-a-flat" types appeared to be some sticky junk with shredded paper - BUT had to be small enough to be put into the tire through the valve stem.
I took my small chain saw {a circular saw works too but makes smaller material} and cut up a small "pile" of wood.
I mixed anti-freeze/wood shavings {just kept mixing until it got what I liked as far as -- not too runny, but just enough} then break down a tire, install as much as I feel is necessary, air back up and go back to using it.
My only expense is the anti-freeze and time, and to date it has worked flawlessly!!!
I HAD a front tire on the Kubota B20 that leaked around the bead and in about a week of no use it would be flat!
I had removed the tire, wire wheeled with a 4" Makita the rim {ALL of it -- center, bead, everything -- Green Slim had almost done it's job on that steel wheel!!!} primed/painted and used the black liquid bead sealer tire shops use around the bead of both tire AND rim then remounted it and back to use. I had done that at least three times with little to no luck.
After "cleaning it up AGAIN" I put my "Johnnie's Special Tire Sealant" :)) in and have not added air since!
That tractor sat for over a month a while back and when I went to load it I took my portable air tank along {I just knew I would have to air up that tire} and simply put the air tank in the loader bucket and back to the shop it went -- still full of air!
I won't use it in a vehicle as highway speeds may cause vibration -- but did break down a tire on my Yamaha Rhino 660 {same issues as above -- leak/break down/clean/paint/seal/remount} and so far at top speed of 36mph have not felt anything and STILL have not added air -- that tire has stayed at 9psi since!
   / Tire Sealant for Slow Leak #26
I have had good luck with this product;
   / Tire Sealant for Slow Leak #27
Had a slow leak in a 18.6-38, added 1 gallon of Slime, no problem since. Had no idea how much, figured really big tire - put it all in.
   / Tire Sealant for Slow Leak #28
Slime has a formula that works with tube tires, you can order on Amazon. I put it in my Kubota L3400DT rear tires 3 years ago and have not had a flat tire since. I also pile and mow pasture with honey locust trees. The stuff works.
   / Tire Sealant for Slow Leak #29
I use hydroseal 1500 in my rear ballast filled tires in a Kubota M4d-074 and 2500 in the front. Broke a valve stem off and completely sealed it- didn’t notice till the next day after using it all day. Works well and can be bought on Amazon or direct from the company.
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
2019 F150 (A61306)
2019 F150 (A61306)
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
