Front Hydraulic Blade
/ Front Hydraulic Blade #1
garbageman
Orange County, NY
Kubota 7500
A quick question
I own a Kubota L2501 and just purchased a front blade for it
I believe it is 5’ model 2736 with skid shoes
My question is should I use the blade in the float position or with some downward pressure
I have a blacktop driveway
Thanks
Ray
/ Front Hydraulic Blade #2
Does your blade attach to the bucket, replace the bucket, or mount to the frame instead of to the loader?
Bruce
Bruce
It is a “ skid steer” type that attaches to the loader arms
/ Front Hydraulic Blade #4
Float if that leaves to much then use small down pressure . If you have to much down your front wheels will come up and you will lose steering
/ Front Hydraulic Blade #5
Do you have pictures? I couldn't find a 2736, but saw a 2763. That one says it mounts on a subframe and was made for a BX?
/ Front Hydraulic Blade #6
I have this setup. Without float you will be frustrated. Set it down, float it and use curl to set cutting depth/aggressiveness. This is all done once you set your shoes. Mine are set so the loader frame is 4” or so off the ground.
/ Front Hydraulic Blade #7
Some times you may not be able to use the float position on the loader,
on some tractors when in float and pushing the load will lift the front tires and put to much load on the blade,
this is because of the geometry of the loader frames. In that case you will need to carry the loader to prevent
lifting the front tires and it will require constant trimming of the loader position.
On a paved driveway the blades weight should be sufficient to get a clean surface depending on how you set your shoes.
/ Front Hydraulic Blade #8
I find that float works well on relatively straight flat road but with the variable conditions of the stuff I plow, I am constantly adjusting the blade to avoid too much or not enough cut.
Thanks for the advice
I will test it out on the next snow
I don’t have the blade in front of me so not sure of the model number
It is a Kubota blade 5-6 long
Most of the time I use a 5’ rear blade with a 2x12x7 bolted on the blade
That works well
/ Front Hydraulic Blade #10
If I float the loader on my L4060 my machine tries to run over the blade & the front is a foot in the air. I really need to reengineer the blade with float between the frame & mount.
My old manual home built blade for my L3200 had float & generally worked good. With plow float I really never tried floating the loader, I expect it wouldnt have worked well either.
Generally plows & loaders are to heavy. Leaving the loader in float puts to much weight on the plow & not enough on the front tires. IMG_20150117_153836-1.jpgIMG_20150117_153817.jpgIMG_20150117_153824-1.jpg20190314_123839.jpg
Chim
Good information
Thank You
I did some more research being that this blade weighing in at 500 pounds
Most owners are not using it in the float position. They letting it “rest”
On the shoes and use the loader control. I will give it a try next snow storm
Ray
I went to my local kubota dealer today and ordered a rubber cutting edge for the front blade
I should have have it in a few days
/ Front Hydraulic Blade #15
I don't float my fel mounted ssqa plow, except in certain conditions. For relatively flat runs I set the blade down so only the weight of the blade (not fel arms) is on the pavement, and adjust as necessary. When the grade changes (like cresting a hill) I will sometimes float the fel briefly, but more frequently when going downhill approaching an incline where the unfloated fel will really dig into the surface. Hope that makes sense...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
