Found a great use for pallet forks
   / Found a great use for pallet forks #41
I managed to move a huge stump using my grapple that I thought was too heavy for my fel to lift. I managed to move it very carefully but afterwards found the damage it did to my fel and grapple. Now to try to figure out the best way to repair it.
   / Found a great use for pallet forks #43
I meant to post in the tractors and wood thread and can’t delete.
   / Found a great use for pallet forks #44
I managed to move a huge stump using my grapple that I thought was too heavy for my fel to lift. I managed to move it very carefully but afterwards found the damage it did to my fel and grapple. Now to try to figure out the best way to repair it.View attachment 769268
Yes, ouch, but you may be lucky the bucket isn't destroyed.
   / Found a great use for pallet forks #45
I thought Kubota was better engineered than this. That top brace that bent on the fel was only tack welded on with about a 9" tack in the middle and another tack on each side. This let the grapple mount twist and bend. I'm going to remove the grapple tomorrow and straighten out the top brace on the bucket and then weld it back all the way across. Then do my best to straighten out the grapple mount but I won't be able to take the twist out of it.
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A57024)
2023 Kubota...
UNUSED FUTURE 32"...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
