ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,737
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
I have used old car hoods to skid big rocks on before.
I get what my rental yard hasI hope you mean a compact telehandler. Mine would pick it up easily: Compact telehandler
I wish I had useful neighbors.My neighbor's Cat TH460 is real easy on the turf like any telehandler is.![]()
Not only invasive and explosively flammable it is exceedingly hard to bush hog. My neighbor and I bush hogged 5 acres of scotch broom and it was like trying to mow down steel cable. Beat the crap out of the bush hog, it needed weld repair after that job.One seems to be farming scotch broom (invasive, explosively flammable
This is the perfect time of year to pull it here, but that takes time and still a lot of effort (and gains you exposure to poison oak).Not only invasive and explosively flammable it is exceedingly hard to bush hog. My neighbor and I bush hogged 5 acres of scotch broom and it was like trying to mow down steel cable. Beat the crap out of the bush hog, it needed weld repair after that job.
Eric
I don't know whether the appropriate response is "Yikes!!", or "Wow!", but either way you have my sympathies.I wish I had useful neighbors.
One seems to be farming scotch broom (invasive, explosively flammable), and another likes to light things on fire that make him run around trying to put it out before I've had enough and call the FD.
It's flat... but the rock is over here and I need to get it to the other side of the house; there's a path to the house but not around & beyond the house on the same levelI don't know whether the appropriate response is "Yikes!!", or "Wow!", but either way you have my sympathies.
Congratulations on finding a nice rock. If it is mostly level to your desired spot, I would consider building a lopsided frame that you could then use log or steel pipe rollers to move into place and then use the long arm of the frame to pull the point to the vertical, and then wedge it in place with rocks or concrete before removing the frame to keep control of it.
FWIW: I use forks on my tractor to rip poison oak out of the ground. It hates to have its roots pulled on, and I have found popping them out the ground is almost always fatal on the first try, especially for large clumps. The quail are always reseeding it from the neighbors, but the cows generally do a good job of keeping the young poison oak to at best an 18" stub.
All the best,
Peter
I'd finish the arch and use the telehandler if it were me. I also might be inclined to rent the next size larger to keep excitement to a minimum. I remember the production of my folks having a large rock moved across the backyard as a kid: first just a backhoe, then the backhoe plus an f600-ish truck, (boulder still wasn't moving), and then a dump truck chained to the rock, and to all the other vehicles other like the Budweiser Clydesdales, and they barely moved it on level dirt. (4x6x2' limestone?) Since you have already moved yours, I am sure that you have a good idea of what it will take.It's flat... but the rock is over here and I need to get it to the other side of the house; there's a path to the house but not around & beyond the house on the same levelit's going to need to be picked up and taken 20' up in elevation, then 50' flat, 40' down the road in elevation, then back up 20' elevation up the driveway - ie the long way around. I think it if was on plywood skidding that it wouldn't damage the roads (dirt first, then blacktop, then exposed aggregate concrete) but it would suck for that to happen.
I didn't get a chance to experiment with the tractor to see how heavy it feels - and probably should just bite the bullet and do a finely detailed measurement of it to get a better estimate of weight. Strong suspicion is that it's going to be waiting for the compact telehandler - at least that gives me yet another reason to get my butt in gear and finish the new gate & arch - three years in the "yeah I need to do that still" list should be almost long enough.
Poison oak: I may give that a try except that my worst spots are on a 60% slope so messing with forks could be iffy just because they're 48" out there and could easily flip the tractor back. I do have a new grapple that while less of a surgical dig I have a big patch (about 30'x40') of major clumps so I could probably sacrifice and just dig the whole area up with the lower part of the grapple without as much front-of-tractor lifting potential. At the very least my goal this spring is to at least grab all the above-ground stuff, even if there's regrowth handling it next year will be less traumatic because it won't be a dense 8' tall jungle of the stuff. It's seriously frightening even though I only get a bit of a rash any more, I just know I'll get scratches from stuff like that.
I've been pulling a lot of it by hand; I find that if I give a light tug and it comes out easily, it has a root network that's right under the duff and above the dirt with little hooks in the dirt and by pulling that out you find a lot that hasn't sprouted yet (this time of year). It's almost like a spiderweb of networked poison oak under the duff and you can actually get most of it without disturbing the duff much. I definitely do eventually find something bigger which I either yank harder or (so far) cut with loppers. I don't know if it'll grow back or not - blackberries would, but they have something that's almost a tuber; smaller shrubs of poison oak definitely grow back if cut/picked (nice bouquet, thanks!) but I'm not sure if the same holds for the inch-plus trunks?
Pulling those stringy roots out seems to be what it takes to kill the poison oak around here. For the big clumps, I pop them out of the ground which seems to crack the roots, and give them a year to air dry and for the sap to deactivate. At that point, I can crush them and safely brush hog them into little pieces.
I have a rock about half that size. My tractor cannot lift it. Using forks I was able to remove enough weight I could drag it. But I want it on top of a 3 foot mound at the entrance to our driveway. Have not found any way to move it uphill.
Hmmm..., maybe they are just bigger in this neck of the woods, or it is just drier more of the year? Some of the bunches had roots and stems three plus inches in diameter that looked pretty much the same a year later.I've found that poison oak decomposes tree
rapidly when dead; I cleared out about thirty square feet of dense growth once and just left a pile by a tree out of the way; the next year it looked like 5% size pile of sticks and the year after that it was unrecognizable.
Yes it is a compact TH, close to the same size as mine, but no SSQA.Cross-referencing pics on the web looks like this is a Genie GTH5519 which has a max lift capacity of 5500#, 4400# to max height.
Checking vs yours, looks like this is about the same thing as far as the forks & maneuverability so I suppose it's a compact TH as well.
Yeah I've seen your posts... i'm kinda jealous lolYes it is a compact TH, close to the same size as mine, but no SSQA.
I have lifted over 6,000 pounds with mine and pulled some big trees with it:
And the size, it fits in the 83 inch high garage door:
