I want this rock
/ I want this rock
I hope you mean a compact telehandler. Mine would pick it up easily: Compact telehandler
I get what my rental yard has
in this case, they don't list a "compact telehandler"; last time I needed something similar I got the 5k telescopic, which was this thing
If I recall we had it for a day; with the delivery (I only have a now-older one-ton truck so couldn't get it myself) I recall it costing a bit over $400.
Cross-referencing pics on the web looks like this is a Genie GTH5519 which has a max lift capacity of 5500#, 4400# to max height.
Checking vs yours, looks like this is about the same thing as far as the forks & maneuverability so I suppose it's a compact TH as well.
/ I want this rock #23
My neighbor's Cat TH460 is real easy on the turf like any telehandler is. (y)
/ I want this rock #24
I've moved many a stone that was too heavy to lift. Rolling logs were by far the easiest. And, I feel they will move a heavier object, but have no proof of that. It does take two additional people to move logs. Using something like a car hood eliminates that. The very first one was damn big and heavy. Used a wrecker to lift it. Front tire were barely touching though, making it hard to turn.
/ I want this rock
I wish I had useful neighbors.
One seems to be farming scotch broom (invasive, explosively flammable), and another likes to light things on fire that make him run around trying to put it out before I've had enough and call the FD.
/ I want this rock #26
Not only invasive and explosively flammable it is exceedingly hard to bush hog. My neighbor and I bush hogged 5 acres of scotch broom and it was like trying to mow down steel cable. Beat the crap out of the bush hog, it needed weld repair after that job.
Eric
/ I want this rock
Eric
This is the perfect time of year to pull it here, but that takes time and still a lot of effort (and gains you exposure to poison oak).
I find that to be more "permanent" than cutting, but with how long the seeds last and how many bushes there are on the neighbor property it's a battle.
It's said you should cut stuff bigger than 1/2" to avoid ground disruption but I figure that's for grounds that aren't often visited by pullers; I make rounds of my land and yank the stuff regularly in the moist months.
/ I want this rock #28
I don't know whether the appropriate response is "Yikes!!", or "Wow!", but either way you have my sympathies.
Congratulations on finding a nice rock. If it is mostly level to your desired spot, I would consider building a lopsided frame that you could then use log or steel pipe rollers to move into place and then use the long arm of the frame to pull the point to the vertical, and then wedge it in place with rocks or concrete before removing the frame to keep control of it.
FWIW: I use forks on my tractor to rip poison oak out of the ground. It hates to have its roots pulled on, and I have found popping them out the ground is almost always fatal on the first try, especially for large clumps. The quail are always reseeding it from the neighbors, but the cows generally do a good job of keeping the young poison oak to at best an 18" stub.
All the best,
Peter
/ I want this rock
All the best,
Peter
It's flat... but the rock is over here and I need to get it to the other side of the house; there's a path to the house but not around & beyond the house on the same level ;) it's going to need to be picked up and taken 20' up in elevation, then 50' flat, 40' down the road in elevation, then back up 20' elevation up the driveway - ie the long way around. I think it if was on plywood skidding that it wouldn't damage the roads (dirt first, then blacktop, then exposed aggregate concrete) but it would suck for that to happen.
I didn't get a chance to experiment with the tractor to see how heavy it feels - and probably should just bite the bullet and do a finely detailed measurement of it to get a better estimate of weight. Strong suspicion is that it's going to be waiting for the compact telehandler - at least that gives me yet another reason to get my butt in gear and finish the new gate & arch - three years in the "yeah I need to do that still" list should be almost long enough.
Poison oak: I may give that a try except that my worst spots are on a 60% slope so messing with forks could be iffy just because they're 48" out there and could easily flip the tractor back. I do have a new grapple that while less of a surgical dig I have a big patch (about 30'x40') of major clumps so I could probably sacrifice and just dig the whole area up with the lower part of the grapple without as much front-of-tractor lifting potential. At the very least my goal this spring is to at least grab all the above-ground stuff, even if there's regrowth handling it next year will be less traumatic because it won't be a dense 8' tall jungle of the stuff. It's seriously frightening even though I only get a bit of a rash any more, I just know I'll get scratches from stuff like that.
I've been pulling a lot of it by hand; I find that if I give a light tug and it comes out easily, it has a root network that's right under the duff and above the dirt with little hooks in the dirt and by pulling that out you find a lot that hasn't sprouted yet (this time of year). It's almost like a spiderweb of networked poison oak under the duff and you can actually get most of it without disturbing the duff much. I definitely do eventually find something bigger which I either yank harder or (so far) cut with loppers. I don't know if it'll grow back or not - blackberries would, but they have something that's almost a tuber; smaller shrubs of poison oak definitely grow back if cut/picked (nice bouquet, thanks!) but I'm not sure if the same holds for the inch-plus trunks?
/ I want this rock #30
A compact track loader might struggle with that rock.
I lightly mist poison oak with triclopyr brush killer. Give it 2-3 weeks to work.
/ I want this rock #31
google "stone boat" There are a couple of different plans online. Been around for centuries. You don't think they carried all the rocks in the stone field walls over there by hand do you?
/ I want this rock #32
I'd finish the arch and use the telehandler if it were me. I also might be inclined to rent the next size larger to keep excitement to a minimum. I remember the production of my folks having a large rock moved across the backyard as a kid: first just a backhoe, then the backhoe plus an f600-ish truck, (boulder still wasn't moving), and then a dump truck chained to the rock, and to all the other vehicles other like the Budweiser Clydesdales, and they barely moved it on level dirt. (4x6x2' limestone?) Since you have already moved yours, I am sure that you have a good idea of what it will take.
Pulling those stringy roots out seems to be what it takes to kill the poison oak around here. For the big clumps, I pop them out of the ground which seems to crack the roots, and give them a year to air dry and for the sap to deactivate. At that point, I can crush them and safely brush hog them into little pieces.
All the best,
Peter
/ I want this rock
I've found that poison oak decomposes tree
rapidly when dead; I cleared out about thirty square feet of dense growth once and just left a pile by a tree out of the way; the next year it looked like 5% size pile of sticks and the year after that it was unrecognizable.
/ I want this rock #34
I have a rock about half that size. My tractor cannot lift it. Using forks I was able to remove enough weight I could drag it. But I want it on top of a 3 foot mound at the entrance to our driveway. Have not found any way to move it uphill.
Call Atlas?
/ I want this rock #35
Hmmm..., maybe they are just bigger in this neck of the woods, or it is just drier more of the year? Some of the bunches had roots and stems three plus inches in diameter that looked pretty much the same a year later.
Regardless, I am happy to have the big brooding five or six foot high bushes of poison oak gone as it seemed like the cows and horses were always brushing against the big bushes, or nibbling them. I got poison oak from a horse putting a bit in his mouth once. It took me awhile to figure the weird pattern of the rash.
All the best,
Peter
/ I want this rock #36
I hesitate to say that if there are good anchor points, a series of pulleys could be rigged to possibly move this rock, but that could be dangerous if a cable were to break.
/ I want this rock #37
Yes it is a compact TH, close to the same size as mine, but no SSQA.
I have lifted over 6,000 pounds with mine and pulled some big trees with it:
And the size, it fits in the 83 inch high garage door:
/ I want this rock
/ I want this rock
minor update...
I stuck the forks under the rock, wrapped a chain around it and to the forks, and got the rock to stand on the forks.
It was near the end of the forks so despite the fact that it's just too heavy, being way out there was ungainly, so I shoved the rock into a couple poles braced against the hillside to get it closer
The loader clearly didn't want to pick up the rock (+ forks), but I was able to drag it backwards a bit.
Got it to a decent location in my turnaround so that there's room for my truck to pass by it
Very convenient of it to have a flat base to stand on. The eventually position will likely be with the rounded end you see on the side set into the ground in some fashion; the opposite side goes to somewhat of a point which I'd like to have going up towards the sky.
Of course it was still on the forks. I used a heavy wall 1½" x 8' metal pipe as a lever and got a wood block under it to unload one fork blade, and found that the other is actually not on the fork with the rock being on the ground.
I ran out of daylight as I had bird chores to do - twilight is curfew for my chickens, ducks and geese, so the forks are still there.
I'll get them free tomorrow, and then leave the boulder as a monolith/monument until I rent the CTH.
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
John Deere Starter Wheel Weights (A65640)
John Deere Starter...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
