Ford 5000
/ Ford 5000 #1
Rambutan
Ford 5000
My Ford 5000 3 point hitch is stuck in the up position. Had been in shed for several months before I started it. Seems to be solid. No movement at all.
/ Ford 5000 #2
Welcome to TBN!! If you've not already done so try opening the lowering speed valve. It's usually a knob or lever between your feet or just behind them.
/ Ford 5000
Tried the control speed valve and bypassing the remote hydraulic system to circulate oil but still no go. Oil pressure ok.
/ Ford 5000 #4
The three point goes up from hydraulic pressure. The down motion is gravity only. If you can't get it down with weight on the arms you may have an internal leak around the control valve forcing it up.
/ Ford 5000
OKAY Looks like I'll have to lift top off and start checking it all out. Thanks
2020 Deere 544L (A60462)
2020 Deere 544L...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
