Ford 5000
/ Ford 5000 #1
Rambutan
Ford 5000
My Ford 5000 3 point hitch is stuck in the up position. Had been in shed for several months before I started it. Seems to be solid. No movement at all.
/ Ford 5000 #2
Welcome to TBN!! If you've not already done so try opening the lowering speed valve. It's usually a knob or lever between your feet or just behind them.
/ Ford 5000
Tried the control speed valve and bypassing the remote hydraulic system to circulate oil but still no go. Oil pressure ok.
/ Ford 5000 #4
The three point goes up from hydraulic pressure. The down motion is gravity only. If you can't get it down with weight on the arms you may have an internal leak around the control valve forcing it up.
/ Ford 5000
OKAY Looks like I'll have to lift top off and start checking it all out. Thanks
2011 Ram 1500 Pickup Truck (A61568)
2011 Ram 1500...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
(2) UNUSED 12.4-16 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 12.4-16...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
429835 (A61166)
429835 (A61166)
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
