Ford 5000
/ Ford 5000 #1
Rambutan
Ford 5000
My Ford 5000 3 point hitch is stuck in the up position. Had been in shed for several months before I started it. Seems to be solid. No movement at all.
/ Ford 5000 #2
Welcome to TBN!! If you've not already done so try opening the lowering speed valve. It's usually a knob or lever between your feet or just behind them.
/ Ford 5000
Tried the control speed valve and bypassing the remote hydraulic system to circulate oil but still no go. Oil pressure ok.
/ Ford 5000 #4
The three point goes up from hydraulic pressure. The down motion is gravity only. If you can't get it down with weight on the arms you may have an internal leak around the control valve forcing it up.
/ Ford 5000
OKAY Looks like I'll have to lift top off and start checking it all out. Thanks
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
