For those with BX with front brush guard
/ For those with BX with front brush guard #21
.......factory uses 950 ft lbs plus a quarter turn:laughing: Several of us have commented how hard it is to break those bolts loose the first time. I was sure I was gonna wring off my allen bit.
I had to go and get an allen-to-1/2" socket to get a breaker bar on them. They were a bear!
/ For those with BX with front brush guard #22
A little tip .Tac weld the nuts to the frame on the back side ,and it makes removing/installing the brush gaurd a breeze.
ALAN
Before you weld the nuts on make sure that they won't interfere if you need to install the snowblower. The quick detach fitting slides over the top of the frame when you remove the front brush guard. And yes I'd like to see the factory gorilla that installed those cap bolts.
/ For those with BX with front brush guard #23
Good catch on that,if it is an issue .I wouldnt know that,for i have a rear blower.Ican have my hood and grill gaurd off in 5 minutes,now that i welded the nuts so they dont turn
ALAN
/ For those with BX with front brush guard #24
Also, do yourself a favor and get your own bolts. Standard, hardened, ACE hardware style. :D
What size are the bolts? I purchased an eBay brush guard and it came without bolts.
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
UNUSED 31" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED 31" HYD...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
UNUSED FUTURE TGT67-67" HYD TRI-TINE GRASS TRIMMER (A60432)
UNUSED FUTURE...
