For those with BX with front brush guard
/ For those with BX with front brush guard #2
Given that the side panels (bonnet?) piece needs to slide out so far, I gotta feeling you aren't going to have room. That said, you only have to pull that side piece when you doing serious maintenance or repair. Once a year? I dunno.
/ For those with BX with front brush guard #3
The shop manual states that you have to remove the guard to remove the cowling. I've done it a few times and it's not too bad. (Block heater, fluid change, etc.)
That is what I was afraid of!
Thanks for the info.
/ For those with BX with front brush guard #6
Air compressor and gun!! :thumbsup: Think NASCAR pitstop.
HA! Removing mine for my 50 hr service, got to use my new IR impact first time :D
/ For those with BX with front brush guard #7
Just be glad you will install the brush guard yourself the first time, that way you control the torque on the fasteners. The factory uses 950 ft lbs plus a quarter turn:laughing: Several of us have commented how hard it is to break those bolts loose the first time. I was sure I was gonna wring off my allen bit.
/ For those with BX with front brush guard #9
I didnt use my own bolts like bp fick suggested. I simply turned the bolts around the other way so the nuts is sticking out the front. This way I can use impact gun to remove it FAST with same bolts! When I first tried to use the allen wrench to loosen it , it was a bear. I used a wrench in behind to loosen and remove bolts. not something I want to do again. :(
/ For those with BX with front brush guard #10
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
