For those with BX with front brush guard
/ For those with BX with front brush guard #2
Given that the side panels (bonnet?) piece needs to slide out so far, I gotta feeling you aren't going to have room. That said, you only have to pull that side piece when you doing serious maintenance or repair. Once a year? I dunno.
/ For those with BX with front brush guard #3
The shop manual states that you have to remove the guard to remove the cowling. I've done it a few times and it's not too bad. (Block heater, fluid change, etc.)
That is what I was afraid of!
Thanks for the info.
/ For those with BX with front brush guard #6
Air compressor and gun!! :thumbsup: Think NASCAR pitstop.
HA! Removing mine for my 50 hr service, got to use my new IR impact first time :D
/ For those with BX with front brush guard #7
Just be glad you will install the brush guard yourself the first time, that way you control the torque on the fasteners. The factory uses 950 ft lbs plus a quarter turn:laughing: Several of us have commented how hard it is to break those bolts loose the first time. I was sure I was gonna wring off my allen bit.
/ For those with BX with front brush guard #9
I didnt use my own bolts like bp fick suggested. I simply turned the bolts around the other way so the nuts is sticking out the front. This way I can use impact gun to remove it FAST with same bolts! When I first tried to use the allen wrench to loosen it , it was a bear. I used a wrench in behind to loosen and remove bolts. not something I want to do again. :(
/ For those with BX with front brush guard #10
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
Freightliner Fuel Truck (A61307)
Freightliner Fuel...
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2020 Chevrolet...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
