For those with BX with front brush guard
/ For those with BX with front brush guard #21
.......factory uses 950 ft lbs plus a quarter turn:laughing: Several of us have commented how hard it is to break those bolts loose the first time. I was sure I was gonna wring off my allen bit.
I had to go and get an allen-to-1/2" socket to get a breaker bar on them. They were a bear!
/ For those with BX with front brush guard #22
A little tip .Tac weld the nuts to the frame on the back side ,and it makes removing/installing the brush gaurd a breeze.
ALAN
Before you weld the nuts on make sure that they won't interfere if you need to install the snowblower. The quick detach fitting slides over the top of the frame when you remove the front brush guard. And yes I'd like to see the factory gorilla that installed those cap bolts.
/ For those with BX with front brush guard #23
Good catch on that,if it is an issue .I wouldnt know that,for i have a rear blower.Ican have my hood and grill gaurd off in 5 minutes,now that i welded the nuts so they dont turn
ALAN
/ For those with BX with front brush guard #24
Also, do yourself a favor and get your own bolts. Standard, hardened, ACE hardware style. :D
What size are the bolts? I purchased an eBay brush guard and it came without bolts.
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
John Deere 6120M (A57148)
John Deere 6120M...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
SP36 VIBRATORY TRECH GRADER (A60736)
SP36 VIBRATORY...
2011 FREIGHTLINER M2 (A60736)
2011 FREIGHTLINER...
