Floatin link purchase
/ Floatin link purchase #1
LabLuvR
SC
Kubota MX5400
My Speedco quick hitch will fit all my implements but the chisel plow. If I could find a floating link similar to the one on my bushhog I would be in great shape. I thought about going to the Bushhog dealer and getting one but there's is much wider than the one I need. After scouring the web I still can't locate what I need. Anyone have any suggestions on where to look? Thanks!
/ Floatin link purchase #2
LandPride part # 320-013A, floating top link assembly for their Cat 1 Quick Hitch will probably fix you right up. See page 11
Worked for me on a Homier QH. Cost $50 bucks, and I only used one component of the assembly - but it was money well spent.
//greg//
The width on the bushing looks too wide to fit the chisel plow. Hmmm, don't know what I am going to do. Just my luck that the quick hitch fits all but one of my implements and it happens to be the one I use the most. Thanks though for the help partner.
/ Floatin link purchase #4
Since there are only 5 part numbers to the assembly, I'm going to assume you're referring to spacer (item 5). The last number is the length; 1.94 inches.
My tool inventory doesn't include a bushing stretcher - but I've found that a hacksaw and a grinder do a fair job of making one shorter.
To be fair, I also bought the bracket in that diagram that's labeled (part of machine). It came with a Cat 1 bushing that fit into the top hook of the QH. Bottom holes of the bracket get pinned to the implement, QH grabs the bushing that's pinned through the top holes. Maybe THAT's the one that could help you out.
//greg//
/ Floatin link purchase #5
</font><font color="blue" class="small">( I thought about going to the Bushhog dealer and getting one but there's is much wider than the one I need. After scouring the web I still can't locate what I need. Anyone have any suggestions on where to look? Thanks! )</font>
If you can't find one ready made, there are any number of us with fab shops either here or locally to you that can fab one for you from a small sketch.
Andy
</font><font color="blue" class="small">( My tool inventory doesn't include a bushing stretcher - but I've found that a hacksaw and a grinder do a fair job of making one shorter.
)</font>
HA!HA! Boy you can tell my skill level is about zero. I should have thought about that! Somtime the simplest solutions are the hardest to come up.
I spent more time last night looking at that dang thing. I refuse to let it whoop me, so I will explore some more.
Thanks for all the help guys!!
Ford 3430 Tractor (A65579)
Ford 3430 Tractor...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2022 EZ-GO ELITE...
