Tires Flat tire on 2305
   / Flat tire on 2305 #11
That would be my bet.. the valve core.
How long between you having to add air? A month or a couple weeks? That's no big deal. I have to add air to the fronts on my ford 850 about once a month so i can move 1000# hay bales on the front end loader...
I'm sure it's a slow valve core leak... but not real inclined to do much untill grass starts to grow..
Soundguy
   / Flat tire on 2305 #12
Dido on the green slime. I had a slow leak on my 2305 front tire put in the recomended amount and haven't had any problems. It has been 4 months. My neighbor has the same tractor and has tubes in both fronts and one back.
   / Flat tire on 2305 #13
I had one front tire go down on my 4010 and slimed both of them. Haven't had any flats since. Unfortunately, Slime won't work on liquid-filled rear tires. They seem pretty tough. No flat on them in 280 hours.
Ralph
   / Flat tire on 2305 #14
some other posters here might have a good point about checking that stem valve. I have found that sometimes all you gotta do is take a valve tool and tighten the valve down a bit.
AND I use SLIME. All four tires on my 2210 are loaded with slime and at least three tires have nail and glass holes in them. I use plugs first in the large nail holes then slime. Seals it up good. No more flats. My experience with tubes is they slow leak.
   / Flat tire on 2305 #15
don't use fix a flat, it'll harden the rubber in the tire and actually cause more harm than good. The green, or yellow slime is a much better option, I run it in all my atv's and never have to worry about flats. I agree that your problem is probably due to contracting air and you just need to add some...though it could be a sticky valve. either way, I'd get a valve repair kit and a couple bottles of slime and do all air filled tires.
   / Flat tire on 2305
Thanks, guys. I'll check the valve stem cores, and if they still leak down, I'll try the slime. As I said, I never lost pressure for about two years. When I started snowblowing this winter, I had left front completely flat (actually came off rim). Reseated, inflated all four, a week later, right front was nearly flat. Inflated both fronts again and posted to you guys for advice. Thanks again and Merry Christmas!
   / Flat tire on 2305 #17
I'm a slime guy too. I run it in my lawn mowers, ATVs and pretty much anything else prone to flat tires and low speeds.
   / Flat tire on 2305 #18
Just a thought, chipsndust. Warm soapy water in a spray bottle (if it's not too cold) spray into valve stem and look for bubbles..no bubbles no valve stem leak, note: you need to be look carefully, it's a small leak, but not so slow, you'll see it if it's leaking.
If you have the time and energy-take the wheel off and bring into a heated area, either spray the bead and tread with the soapy water or fill a large tank and dunk it, look for tiny bubbles. Then you'll know what's happening. I've got to do that also, one of my front tires loses enough air that I'm adding 5psi every 2-3 weeks, not a lot but agravating. Every moment counts til I win the lotto and can quit working..:rolleyes:
   / Flat tire on 2305 #19
I had tubes put in my front tires. The weight from the loader kept rolling the bead during sharp turns and it'd loose pressure. Tubes work awesome....
   / Flat tire on 2305
Steadite:
That may be my problem. I never had trouble rolling the beads while using the loader (I did a lot of loader work last summer), but it seems to happen when I'm using the front mounted snowthrower. I didn't notice if the tires were low before I started snowthrowing. I haven't checked in a couple of days to see if they are holding pressure, but I'll be sure from now on to check before I start work.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2009 PETERBILT 340 FLATTOP SLEEPER (A58214)
2009 PETERBILT 340...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 John Deere 624K (A55272)
2012 John Deere...
