Buying Advice First time on 5 acres - tractor selection?
/ First time on 5 acres - tractor selection? #61
I have 12.7 acres and mow about six acres of that which is fairly level except for the ditch along the highway, I mow the ditch and around the camper with a 54 inch Cub Cadet zero turn, used to mow the whole thing with my zero turn until about 4 weeks ago, I decided to go with a scut with a 60 inch mmm and FEL to use on my property and I also bought a box blade and back blade to use with it, my driveway is about 300 feet long maybe a bit more and made my own drag to help keep it clean and I am thinking of getting a land rake.
For winter I am looking at buying a soft cab called The Original, that way I can remove it after winter when not needed.
This is part of my six acres.
My new Sub Compact.
/ First time on 5 acres - tractor selection? #62
Yes. The statement was about trenching. Excavators are better at trenching than backhoes. They're also better at general excavating.
You are changing the subject. You backhanded a comment someone made about trenching and turned it into a post about general excavating.
"Backhoes excel at trenching"... over what? A shovel? Certainly not an excavator.........Excavators are way better at the task than backhoes. Positioning is faster, you can get them into tighter spaces, you can rotate 360 degrees, etc...
Your statement above says that excavators are WAY better than backhoes at TRENCHING. This is just plain not true.
/ First time on 5 acres - tractor selection? #63
Hi all- thanks for all weighing in. A couple of notes: I don稚 plan on getting any finish mower anytime soon since the front yard (the only section with a true lawn look) is only about 1/8 acre. I have a self propelled push mower for that and if I can pick up a cheap rider or ZTR down the road I think I could call that good.
With regard to the backhoe: the French drain project is the shortest term one. That is about 200 long. In the next few years I will also probably be building a little cabin for guests and want to do some site work for that, and running power out about 300? I may also be burying cable for ham radio antennas in the next year or so. One of the scary things about renting would be that it would be my first time operating a BH- so its not clear that I could make efficient use of my rental.
Really appreciate the weigh-in from everyone. If I took a look at the new holland lineup, does anyone know a pound for pound and HP competitor to the L2501? Do the hydraulics on the new holland allow for multiple operations (lift and curl, etc?)
Leaning strongly towards the L2501 at present.
im biased! very satisfied with this tractor. 20hrs on the clock and running it like i stole it!
definitely worth a test ride.
/ First time on 5 acres - tractor selection? #64
I’ve never ran a tracked back hoe much but through my job I’ve worked around a lot of heavy equipment. For serious trenching all contractors use a tracked back hoe for a job of any size. The video is a little bit of a joke since tracked back hoes can get really big and will easily out perform the TLB.
The OP sounds like he wants a backhoe and does not want a mid mount mower, so those arguments can be dropped.
/ First time on 5 acres - tractor selection? #65
I was a new land owner 2.5 years ago, with my limited budget I purchased an older Kubota, an L35. It is a compact but heavy duty, around the 5700lbs. The FEL will lift 1650lbs and the backhoe is heavy duty to match. I love the backhoe, it has been invaluable for the landscaping work.
/ First time on 5 acres - tractor selection? #66
For ease of removal, check out the backhoe on the new Kubota BX23S. They also have a quick attach function that you can get for the front end loader. I know that the BX23S is smaller than the B 2501, but their horse power ratings are about the same and yes, Jeff, the B 2501 is heavier, but I get by with my BX 25, and I have two properties one of which is 25 acres. And even without the quick detach feature that is now found on the newer BX, I can still remove and replace my backhoe quite easily.
/ First time on 5 acres - tractor selection? #67
I don稚 care that they were equal. If time is important use a big bucket to dig a big hole. My 18 backhoe bucket holds 5.3 cubic feet. My 36 holds over 15. It痴 obvious which one moves more dirt. I didn稚 even finish the video to see that part. I致e used a mini to dig ditches before and i hated it. My backhoe would be way faster.
You can't put a bigger bucket on a compact tractor backhoe that would compete with a small excavator. That's what we're talking about. A compact tractor for the OP and if he can justify the cost of a backhoe for it VS just renting a small excavator. Does he have enough tasks to justify the cost VS if he just planned out his projects, could he knock them out with a couple weekend rentals each year. A small excavator will outperform a compact tractor backhoe in every digging task. Unless he steps up to larger and larger tractors or dedicated TLB, the small excavator digs better.
The whole point of the discussion is if the cost of a backhoe attachment on a compact tractor for limited jobs on a 5 acre property is worth the investment or not for the OP VS renting. In my opinion, from his task descriptions, it's not worth the cost if there's rental equipment available.
/ First time on 5 acres - tractor selection? #68
The cost of using a backhoe for random invented jobs; priceless.
/ First time on 5 acres - tractor selection? #69
BTW, it might be wise to get to know your neighbors. I have a guy 3 miles from me that does the limited amount of BH work I need on my 20 acres. In the 6 years I have lived here, it has cost me $500 or so....and I do not need to store the darn thing or learn how to use it.
But if you want a new toy and can afford it, go for it. IMHO, Your work list does not justify it. You will get a lot more out of a nicer machine and more implements. May not be what you want to hear...just my $.02
/ First time on 5 acres - tractor selection? #70
Yes it is. Start looking at job sites. You see fewer and fewer backhoes and more and more excavators. There used to be many backhoe services around here. Now there aren't. They all are switching to excavators and skid steers. The only one I see around here with a backhoe on a regular basis is one cemetery burial service. The other cemeteries are switching to excavators as well, because they can get into and out of tight spaces easier, cause less dame age to repair, are les expensive to operate, etc...
/ First time on 5 acres - tractor selection? #71
This I agree with. If someone has the means to afford a nice tool, go for it. Just don't include the ROI in the figures.
/ First time on 5 acres - tractor selection? #72
ROI: figure in the cost of golf club membership, green fees, equipment cost, travel cost. & refreshment cost and it may even out.
/ First time on 5 acres - tractor selection? #73
There you go again, more statements that have othing to do with the TRENCHING post you started these comments about.
That said:
An excavator is better at all around digging.
A backhoe is better at general purpose and is NOT limited to digging.
/ First time on 5 acres - tractor selection? #74
An excavator is better at trenching than a backhoe. That clear enough? :rolleyes:
/ First time on 5 acres - tractor selection? #75
Slightly better as I have said, not way better as you have said, I am glad you are seeing it my way :thumbsup:
A backhoe is better than an excavator for general purpose. :rolleyes:
/ First time on 5 acres - tractor selection? #76
Excavators and backhoes each do work they are well suited for. It’s just using the proper equipment for the job at hand or utilizing what’s available at the best cost.
/ First time on 5 acres - tractor selection? #77
Exactly!
/ First time on 5 acres - tractor selection? #78
Real question is on the backhoe, what do you have in mind. If its one project, I suggest skipping the 7k purchase and renting an ex, only 2-300 for a day or about grand for a week. One day on an ex a competent operator can get a lot done.
/ First time on 5 acres - tractor selection? #79
First, if someone wants a machine and can afford it, great. It's just like buying a new car or truck. I've purchased many things in my life that I did not need, but wanted. I have no argument there.
However, I enjoy looking at how much things actually cost over time. By managing our costs carefully and honestly over the past 40 years, it has served us well, and hopefully, people can see that is the point of the buy VS rent discussion; which option makes more sense for each individual?
Per Kubota's build your own website, the BH77 backhoe for an L2501 is a $7K option. It digs 7.7'. Here's a link to the full specs.
Kubota | BH77
I've seen them used for $5k, but most are well over that. Many have "call for price".
I can rent a Bobcat E32I with thumb and trailer for $360 a weekend with unlimited hours. It digs 10' 2". Here's a link to the full specs.
E32 Excavator Specs & Options - Bobcat Company
That excavator will seriously outperform the BH77 in all digging tasks. It's got longer reach, deeper depth, higher height, twice the arm force, twice the bucket force, can rotate 360 degrees, and can get 90 degrees to an immovable object like a wall or fence, to name a few. It also has a cab, and from comments I've read, is more comfortable than the operator's station on the BH, which contributes to operator fatigue. It will do more work in less time, the end. Let's move on to costs.
I'd have to do 19.4 weekend rentals to = $7K, and I'd have to put at least 310 hours on the tractor with backhoe based on 8 hour days to = the rental machine hours if they were limited to 8 per day, which they aren't. But that doesn't take into consideration that the excavator will do more digging in the same time as that backhoe. With the specs listed for both, one can only guess that it'll do X-% more digging in the same amount of time as the backhoe. It's larger, stronger, faster, more maneuverable, etc... I'd guess, given the larger size of the excavator VS that BH77 it will be significant. Like 25-30% more at least. That's based on my personal use of that particular excavator, and watching small backhoes. They just seem a lot slower than that excavator. Based on that, I'm going to add 25% hours of operation to the tractor with backhoe and bump that 310 hours to 387.5 hours on the tractor VS 320 on the rented excavator (again, the excavator is unlimited weekend hours, and I'm limiting my usage to 8 per day for comparison, but I could legally put way more than 16 hours on the rental in a weekend if I had the inclination).
It's been stated many times on TBN that the average compact tractor owner puts about 50 hours per year on their machine. So that 387.5 hours equates to about 7.75 years of average usage taken off the machine by doing backhoe work with it. Figure that into the equation as well and consider the wear and tear the backhoe will impart onto the tractor and all of its components. It all takes a toll. You also have to store it when not in use and maintain it. You also have to remove it from the tractor anytime you want to use the 3pt hitch for some other attachment, then put it back on when needed again. Some are easy, some are not. I don't think it's that big of a deal, but it needs to be mentioned.
If you have a tractor with an FEL and rent an excavator, you can do the excavating with the excavator, and transport any materials with the FEL. If you have a backhoe on the tractor, you have to change seats and reposition the machine in order to transport materials any distance. You can also have a 2nd operator to run the tractor with FEL while you operate the excavator, so more work in less time due to 2 machines on site.
Of course, there's an advantage to having a backhoe on site 24/7, and that's convenience. You don't have to plan out projects meticulously to maximize your rental dollars/hours, or wait for a weekend and hope the weather is good (excavator had a cab), your mother-in-law Sheila needs something, etc... You can do them ASAP or at your leisure. You decide when you want to work. That can be priceless to some.
It's just that in many cases, and I'd guess more than less, the real economic advantages of owning a backhoe on a compact tractor for most homeowners isn't there when you add everything up. While the convenience advantage is downright outstanding, and if you can afford it, and want it, go for it. I would too. Just don't try and justify it economically. The dollar numbers aren't usually there for most homeowners. And that's my thoughts on the subject.
OP, good luck in your decision making. :thumbsup:
/ First time on 5 acres - tractor selection? #80
MossRoad, I tend to agree with your assessment with one difference. As you mentioned a used BH appears to be worth around $5k, so instead of calculating the hours based on $7k, should it not be calculated abased on $2k? That changes it quite a bit to 5.5 weekends of rental. I still would not buy the BH for my specific purposes but only the OP knows how it fits in their plan. Lots of ways to look at it.
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
John Deere 4955 (A64119)
John Deere 4955...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
