Tires filled tires
/ filled tires #1
bigbrntrck
tx
whats the deal with filling tires???? i live in hou. the weather is always warm, my dealer said they could fill the tires if i wanted with water. im gonnna get a 1428v with R4s. willl the water ruin my rims?? the only bernifit i see is a little more weight. any sugggestions or comments welcomed. /forums/images/graemlins/confused.gif
/ filled tires #2
Filling tires is meant to add weight especially when using a FEL. Being you are in a warm climate filling the tires with water shouldn't hurt. I don't know how it will hold up over the long term though regarding corrosion.
/ filled tires #3
Hi,
The tires should ( better ) have tubes in them. So, maybe check with the dealer incase.................
Will
/ filled tires #4
Always fill tyres to 2/3 - This reduces the centre of gravity and will give the tractor a bit more weight or momentum. Add anti freeze if you are in a cold area. Be carefull removing wheels of loaded rear tyres as they are very heavy and the weight will shift- always use a chain block - people have been crushed by loaded rear tyres.
/ filled tires #5
Hi,
In cold climates Calcium Chloride is commonly used. Thats what is in our rear tires.
Take care
Will
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
(2) 380/85R30 TIRES W/ 8 LUG RIMS (A64280)
(2) 380/85R30...
(2) 25X10.00-12 TIRES ONLY (A64280)
(2) 25X10.00-12...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
