Tires filled tires
/ filled tires #1
bigbrntrck
tx
whats the deal with filling tires???? i live in hou. the weather is always warm, my dealer said they could fill the tires if i wanted with water. im gonnna get a 1428v with R4s. willl the water ruin my rims?? the only bernifit i see is a little more weight. any sugggestions or comments welcomed. /forums/images/graemlins/confused.gif
/ filled tires #2
Filling tires is meant to add weight especially when using a FEL. Being you are in a warm climate filling the tires with water shouldn't hurt. I don't know how it will hold up over the long term though regarding corrosion.
/ filled tires #3
Hi,
The tires should ( better ) have tubes in them. So, maybe check with the dealer incase.................
Will
/ filled tires #4
Always fill tyres to 2/3 - This reduces the centre of gravity and will give the tractor a bit more weight or momentum. Add anti freeze if you are in a cold area. Be carefull removing wheels of loaded rear tyres as they are very heavy and the weight will shift- always use a chain block - people have been crushed by loaded rear tyres.
/ filled tires #5
Hi,
In cold climates Calcium Chloride is commonly used. Thats what is in our rear tires.
Take care
Will
John Deere 6130M (A64126)
John Deere 6130M...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
iDrive TDS-2010H...
2017 Kenworth T680 (A64127)
2017 Kenworth T680...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
