Tires Fill Tires or Add Weight?
   / Fill Tires or Add Weight? #41
Removing weight and adding it again on any semi regular basis is not how I like to spend time.
If I needed to trailer, I would happily purchase a trailer with an additional 1k to 2k lb towing capacity in order to save myself the time and agony of removing and re-adding weight. Plus as George says - what if you need the weight where you are going.
I've got the tires filled on my L3400. Got it done well over a year after I purchased it and the difference is enormous. Weights for this size of tractor wouldn't add the same amount of ballast and were 2x more expensive for a lot less ballast.
I would have happily added wheel weights if the amount of ballast were near equivalent and the cost no more than 25% to 50% more than fluid filled tires. I don't think that I would be taking the weight off one way or the other.
Realistically a 3PT weight alone is not adequate for me. I often decide to use my loader with a rake on or some other fairly light weight implement. The odd time it is without anything on the back. Having the weight as part of the tractor - wheel weights or otherwise makes the most sense to me. I have a ballast box too and if I know I am lifting something heavy I will put that on.
JMHO.
   / Fill Tires or Add Weight? #42
And that brings us around to the expense thing again. Its been two years since I priced wheel weights but when I saw the price I 'bout had a stroke.
Does anyone make aftermarket wheel weights that would fit a variety of tractors at a lower price than the tractor brand weights?
   / Fill Tires or Add Weight? #43
Wouldn't some kind of water tank make sense?
jake (checking my spelling closely)
   / Fill Tires or Add Weight? #44
I've thought about that too. Good idea for trailering etc. But again, its going to tie up your 3pt hitch with something that is otherwise useless....unless you are moving water.
   / Fill Tires or Add Weight? #45
I know dealers price differently, cast is normally about a dollar a lb for the weights.
   / Fill Tires or Add Weight? #46
Yep, that's steep. The dealer filled my tires for free. Adds a total of 800 pounds. That's $0.00 per pound.
   / Fill Tires or Add Weight? #47
Most dealers will load rear tires for free on tractors equipped with loaders. In the long run, this is cheaper than paying for lawyers, etc. when a customer tips an improperly ballasted tractor.
   / Fill Tires or Add Weight? #48
Hey my dealer did not loader the tires or sell me a ballast box as part of my sale :)
I found out that I ought to have ballast from TBN and asked them to deliver a ballast box with my tractor.
I would most certainly recommend that a new buyer have loaded tires or weight of some sort thrown into the deal.
   / Fill Tires or Add Weight? #49
I don't need loaded tires or extra weight.
1 tractor has a FEL and BH on it.
Another 1 has a front blade and rear tiller on it.
The 3rd just has A MMM on it so no weight on front or rear is needed.
WOW! I love this place. Thanks for all the info. Since my only current need for weight is heavy FEL work I guess I'll build a 3pt weight.
   / Fill Tires or Add Weight? #51
I'd doubt it! You paid some where but it's all right if you think you got them filled for nothing.
   / Fill Tires or Add Weight? #52
I was thinking the same thing. I see N80's reply about tieing up the 3ph, but why not have a liquid ballast tank mounted somewhere else, like inboard of the fenders?
Some of the local farmers have these liquid tanks at the front end (front bumper) of their row crop tractors. As you may know, for pulling it's often useful to have weight in front instead of rear to keep the front from lifting up. I don't know for sure what the tanks are for, but they look too small and in the wrong place for sprayer tanks, so I can only guess they are a ballast tank. They look basically homemade, but it seems like a good idea to me. Oh yeah, companies that make those row crop tractors will sell you suitcase weights for the front end, but I am guessing the ballast tank is cheaper and more flexible.
   / Fill Tires or Add Weight? #53
Those front tanks may possibly be auxilary fuel tanks. Fairly common practice, especially on tractors that spend long days in the field.
   / Fill Tires or Add Weight? #54
For loader work it is important to have enough weight in the back as well as behind the rear wheels to offset weigth and wear on the front wheels. To be able to use the bucket to fill up from solid ground you need traction that only weights can provide. I started with disk wheels in the rear and went to CI hubs with filled tires and then mounted a 2000 lbs ballast box on the three point and now I am going to add additional CI wheel weights. Also I have set the wheel out to gain additional stability
   / Fill Tires or Add Weight? #55
As moutainview said.. not always can you just let your balalst pee out on the ground. if it is cacl.. you will kill grass.. if it is rimguard.. you want to save it because it is expensive. If the tubes popped.. it won't pee out real well.. though certainly some will.
I've changed rear tires as large as i could get flipped over by myself. I've changed a few that were on their side and too big to pick without using mechanical advantage.. sure is no fun.. and ain't fast by yourself either. All it takes is practice.
At work.. we have plenty of industrial equipment that have tires way bigger than agg applications. if we call a tire service.. they only ever send one man. Using his tools and the hoist on his truck.. I've never seent he local tire guy NOT be able to change a tire byhimself.. including some where the rubber must have weight near a ton, and with center.. probably another thousand... enough to make his truck squatt when he stood it up. ( I'm glad I'm not him.. I hate tire work! in fact.. anything other than fronts.. I -usually- hire out now.. unless I got the casing and tube in the farm and I'm pinched for time.)
I guess my point about the balalst is as much money and hassle as it is time.. not that a wet tire is specifically harder.. just more to think about.. and that many 'wet' tires are tube tires..and by default.. plugging a tube tire is / can be more work than a tubeless.. etc.
Soundguy
N80 said:
If you can completely dismount and remount a rear tire on a full size Ag tractor by yourself, well, you're three times the man than me, my farmer friend and his farmer buddy. My hats off to you. I've BTDT and the three of us struggled with this thing and two of the three of us knew what they were doing.
But your point is well taken, and its my point too, mounting and remounting a tire by hand is hard. A little harder if you have to deal with the fluid, but hardly a reason not to use fluid.
I don't follow this stuff about storage, pumps, removal time.....pop the valve, out it comes. Done. Maybe you are neater than we were.
Hey, no problem. Some have it and some don't. We just don't have it I guess. Those two tires kicked our behinds. Three of us. If you can do it by yourself, again, my hats off to ya. You da man! But again (and again and again) my point is that its a hard job whether you are one super guy or three stooges. The fluid doesn't, and didn't (in our case) add anything to that difficulty.
   / Fill Tires or Add Weight? #56
Sure, you pay for everything. I get it. But considering that I got the best price on a 4wd L4400 with FEL that I've seen anywhere, at any time, ever, I think it probably came out in the wash.
   / Fill Tires or Add Weight? #57
jake98 said:
George (and the rest of you knuckeheads), How about when you put a tractor on a trailer? I don't think I want another thousand pounds...
Jake
Well Jake, everybody doesn't move their tractors, so being able to put it on a trailer is not even a factor. And besides that some of us have trailers that can carry a bit more than the tractor with a few thousand pounds of extra ballast. Our tilt bed can carry our D6, do you think that I worried about an extra 2600lbs of ballast when I ballasted my Mahindra? Honestly, my only consideration was to make it as heavy as possible. Now I have no intentions of moving my Mahindra, But I can if need be. Now I'm sure that some others are like me and can get about anything moved and others have trailers just for their particular machine and yet most don't have a trailer at all and have no intentions of moving their tractor ever. As far as you not wanting another 1000lbs when moving your tractor, fine don't add any extra weight then, that's up to you to have less pulling power.
   / Fill Tires or Add Weight? #58
As long as you feel you did right, that's the most important part!
   / Fill Tires or Add Weight? #59
Some good points have been brought up about filling tires. Calcium does kill! Rim guard does cost about the same as the cast weight. The bulk of the filled tires are just that, no tubes. If you hit a solid dead furrow you stand to loose most of it in that tire.
It still goes back to what you feel is needed but if at all possible to start with the cast and then move on. You can always trade the cast for filled!
   / Fill Tires or Add Weight? #60
PERFECT!!
A perfect example, that is, of analyzing an intended use, and applying a simple, yet effective, solution.
There are trade-offs and Pros and Cons to all of the various weighting methods. Each task/job/chore may dictate one method or the other or a even a combination.
In my most recent case, I needed weight for traction while plowing snow with my small 4WD. Loading my rear tires with liquid would give a lot of weight and would work, However, in the spring, summer and fall I just don't need the liquid in there. So, I looked at my situational needs. Hanging weight off of my 3PH would be easy, give more rear weight, but would tend to lighten the front end and that wasn't the optimum , at least in my mind. I like the traction i get with the front tires firmly planted and keeping stable steering helps too.
So, it looks like I need to keep the existing tractor's weight on the front end and need to increase weight on the rears (mostly because that is where 75% of my rubber touches the ground). I chose wheel weights and am adding some barbell discs to the drawbar/pin hitch area, which is fairly close to the rear axle to avoid excessive front-end lift.
I'll bolt-up the wheel weights in November and remove them in late March. Done. Don't need them for mowing. I'll install the 25# discs on the rear hitch area only when it snows. They install and remove very easily. They block the PTO, but, i don't use the PTO when plowing, so, no conflict there.
In closing,
This long winded explanation of my personal needs was not intended to convince anyone my method is better/cheaper/more effective than anyone else's.
It was an example of the type of thought process each task dictates, to find the optimum weight set-up for the chosen task at hand, whether they be 100% of the time, or seasonal, or even, in the case of a 3PH ballast box, per a single usage.
The intended use and desired effect helps deteremine the optimum solution.
1981 Kari Kool CTK 6,500 Gallon T/A Tanker Trailer (A59230)
1981 Kari Kool CTK...
Rooster Weathervane (A55853)
Rooster...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2019 Ford F-350 (A55973)
2019 Ford F-350...
