ctpres
I use my tractor some on sandy yard and am not real excited about filling tires and leaving tire tracks/ruts. I like idea ofremovable weight on rear. Is there any reason filled tires are better?
I don't want weight I can't easily remove.ctpres said:I use my tractor some on sandy yard and am not real excited about filling tires and leaving tire tracks/ruts. I like idea ofremovable weight on rear. Is there any reason filled tires are better?
art said:The trend on ag tires is for solid weight not filling tires as it's been found that the liquid doesn't allow the tire to flex causing a loss of traction over comparable solid weights. This also causes premature tire wear from slippage.
Some insist on loading the tires for the weight when using their tractors predominitly for loader work. It is far more benificial to add the weight onto the three point so it would use the rear axle as a pivot point to reduce the load on the front axle. This way the steering components as well as the drive will last longer.
It seems that approximately 1/3rd less of cast weights can be used to accomplish the same as the liquid filled tires.
lhfarm said:When I purchased my tractor, I specified filled tires. My old tractor had filled ag tires. The salesman, an older gentleman, insisted that I go with wheel weights. He went so far as to give me the weights for what I would have paid for fuild. He believed the long-term problems - mostly rim rot - just weren't worth any advantages filled tires might have. I've not regreted that decision.
Here is a great tip on handling the weights for easy installation or removal TC-40D Adding tractor weights
Farmwithjunk said:Why would you think 1/3 less weight (of cast wheel weights) would accomplish same as fluid? Less weight carried on the 3-point hitch would accomplish the same as weight carried on the axle in regards to loader work.
Be it cast or fluid, weight is weight. No matter what form, carried on the axle, cast or fluid would provide the SAME amount of ballast. Cast ballast carried on the hitch would limit use of the hitch for implements.
montanaman said:Because on the three point, the weight is farther back on the tractor and behind the rear axle, the weight provides leverage to in effect lift some weight off of the front axle. If we are talking cast weights on the wheels, then other than additional stability from the lower weight of filled tires, then weight is weight.
If the weight is something that you would ONLY want on while doing loader work, then weight on the three point is hard to beat.
daTeacha said:I do not use filled tires since a lot of my work is in the woods and a puncture would be a lot less fun with the tire filled.
N80 said:Why is that? A flat is a flat.
Z-Michigan said:To fix a flat with air in tires, you simply insert a plug, or worst case remove the tire and patch from inside (removing tire may not by DIY depending on tire size and your skills).
With fluid in tires you have to pump out all the remaining fluid, store it or dump it somewhere, dry the flat area, fix the flat, and then re-fill the tire with fluid. More time spent, and most likely requires a professional tire service vs. possibly doing it yourself with just air in tires.
Farmwithjunk said:I also questioned why cast weight on the axle would be "heavier" than 1/3 MORE weight from fluid in tires.
kozak said:Therefore, the further out you put the same weight behind the pivot point, the more force (or counterweight) you have available to balance the front end.
Vic
On the 3pt ballast topic, that was my point as well. I do not want to rely on the 3pt as the weight I need for stability when using the loader. My box blade functions very well in this capacity, but what if I want to have a middle buster or two bottom plow on there (very little ballast from those) and still use the loader some? When that occurs I'm glad to have weight in the tires, or on the wheels. And for me it is not unusual to multitask that way so it isn't a trivial issue. I always prefer to have some weight on the 3pt, but when I can't the filled tires are very reassuring.
