Tires Fill Tires or Add Weight?
   / Fill Tires or Add Weight? #41
Removing weight and adding it again on any semi regular basis is not how I like to spend time.
If I needed to trailer, I would happily purchase a trailer with an additional 1k to 2k lb towing capacity in order to save myself the time and agony of removing and re-adding weight. Plus as George says - what if you need the weight where you are going.
I've got the tires filled on my L3400. Got it done well over a year after I purchased it and the difference is enormous. Weights for this size of tractor wouldn't add the same amount of ballast and were 2x more expensive for a lot less ballast.
I would have happily added wheel weights if the amount of ballast were near equivalent and the cost no more than 25% to 50% more than fluid filled tires. I don't think that I would be taking the weight off one way or the other.
Realistically a 3PT weight alone is not adequate for me. I often decide to use my loader with a rake on or some other fairly light weight implement. The odd time it is without anything on the back. Having the weight as part of the tractor - wheel weights or otherwise makes the most sense to me. I have a ballast box too and if I know I am lifting something heavy I will put that on.
JMHO.
   / Fill Tires or Add Weight? #42
And that brings us around to the expense thing again. Its been two years since I priced wheel weights but when I saw the price I 'bout had a stroke.
Does anyone make aftermarket wheel weights that would fit a variety of tractors at a lower price than the tractor brand weights?
   / Fill Tires or Add Weight? #43
Wouldn't some kind of water tank make sense?
jake (checking my spelling closely)
   / Fill Tires or Add Weight? #44
I've thought about that too. Good idea for trailering etc. But again, its going to tie up your 3pt hitch with something that is otherwise useless....unless you are moving water.
   / Fill Tires or Add Weight? #45
I know dealers price differently, cast is normally about a dollar a lb for the weights.
   / Fill Tires or Add Weight? #46
Yep, that's steep. The dealer filled my tires for free. Adds a total of 800 pounds. That's $0.00 per pound.
   / Fill Tires or Add Weight? #47
Most dealers will load rear tires for free on tractors equipped with loaders. In the long run, this is cheaper than paying for lawyers, etc. when a customer tips an improperly ballasted tractor.
   / Fill Tires or Add Weight? #48
Hey my dealer did not loader the tires or sell me a ballast box as part of my sale :)
I found out that I ought to have ballast from TBN and asked them to deliver a ballast box with my tractor.
I would most certainly recommend that a new buyer have loaded tires or weight of some sort thrown into the deal.
   / Fill Tires or Add Weight? #49
I don't need loaded tires or extra weight.
1 tractor has a FEL and BH on it.
Another 1 has a front blade and rear tiller on it.
The 3rd just has A MMM on it so no weight on front or rear is needed.
WOW! I love this place. Thanks for all the info. Since my only current need for weight is heavy FEL work I guess I'll build a 3pt weight.
2007 Freightliner M2 106 Medium Duty Pac-Mac RL10 10 Yard Refuse Garbage Truck (A55852)
2007 Freightliner...
2022 Padget Morris Electric Mobility Scooter (A55853)
2022 Padget Morris...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
19088 (A55758)
19088 (A55758)
2022 John Deere 1025R (A53317)
2022 John Deere...
