Front-End Loader Favorote Quick Attach FEL attachments???
   / Favorote Quick Attach FEL attachments??? #31
I don't know how BukitCase can wait to utilize his new toy? I felt compelled to get mine hooked-up the day it arrived. Even though it was 14F weather! I'll manage tol get some pictures posted pronto.
   / Favorote Quick Attach FEL attachments??? #32
Louie, don't have a lotta choice - I'm still recovering from rotator cuff surgery, plus a complete right biceps re-attachment. Gonna be a while before my friends quit calling me "lefty"...
Also, I have several projects planned for the BH that will require 3 new hyd. circuits at each end - a 3 position, one with float, and a motor control/flow control for loader bucket AND for the hoe bucket. I'll need to run hard lines along the hoe sections and loader, then set up QD's for each, build a mount for the right fender for two 3-section valves, plumb it all up, likely add a transmission cooler in the return (flow controls tend to add heat) - All this in addition to modding the front bucket for QA (See Puckgrinder's thread) -
Hopefully I can get this all done before I croak, 'cause it will definitely make things a LOT easier to keep on top of if I'm doing it with little levers instead of BIG, NON-hydraulic tools :=)
Sooo, it's not like I'm actually WAITING - I'm just not DOing much... Steve
   / Favorote Quick Attach FEL attachments??? #33
Lefty, Sounds like you have a busy future. Good luck with all the upgrades and especially your recuperation. Getting this samurai was a big project for me -- tells you what my skill level is!
   / Favorote Quick Attach FEL attachments??? #34
Yeah, don't plan to be bored unless I live to be 180 :=)
I'd been trying for the last year to find a usable sickle bar for less than $1200 that was worth bringing home, followed by probably a month of messing around and another $600 in hydraulic parts/steel, etc, when the Samurai popped up (here, of course:=) so I consider myself lucky NOT to have had that particular experience (modding an old pitman arm relic trying to make it "petite" enough to handle, etc)
BTW, on their website FAQ's one of the questions was whether the teeth were smooth or serrated - the answer was "smooth, so you can re-sharpen" - yet mine showed up with serrated teeth. Same with yours? Just curious... Steve
   / Favorote Quick Attach FEL attachments??? #35
Here are a few photos of my new saw. The teeth are serrated, and appear easy to remove.
   / Favorote Quick Attach FEL attachments??? #37
I have several nice FEL attached implements...but my favorite HAS to be my snowblower. Its powered by a 3 point attached 25 gallon hydraulic tank hooked up to a 3,000 PSI, 15 GPM pto powered pump. I hope to add the loader mounted post hole digger some day.side view blower and bracket 1.jpgready to blow roof.jpg
   / Favorote Quick Attach FEL attachments??? #38
I have a front three-point adapter and use my carryall on the loader all the time. I find it to be very convenient to just go grab it with the loader when I need to move something and not have to drop the rear mower.IMG_2003.jpg A loader mounted trailer hitch is also very handy.IMG_1459.jpg
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Eagle Weathervane (A55853)
Eagle Weathervane...
John Deere 5055E (A53317)
John Deere 5055E...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2014 Forest River Rockwood Premier Pop Up Trailer (A59231)
2014 Forest River...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
