Front-End Loader Favorote Quick Attach FEL attachments???
   / Favorote Quick Attach FEL attachments??? #21
Hydraulic post hole digger for front mount FEL. I don't have actual pictures of mine yet (these are stock pictures), but if you get one, make sure you get the offset set up (second picture) so you can see what you are digging. Otherwise if you get a center mount one intended for skid steers you may need a second person on the ground to guide you. These FEL mounts are way better than 3 pt as you don't have as much of the wobble that a 3 pt allows (sometimes holes then go at an angle) plus you can reverse the auger if you get stuck under a root or rock and can't lift the auger out. If you already have hydraulics for a grapple, you should be set. Otherwise you will need to add them. Make sure you don't oversize the hydraulic motor depending on your hydraulic GPM capacity.
   / Favorote Quick Attach FEL attachments??? #22
I ordered a hydraulic drive sickle bar which attaches to my bucket. This will be useful trimming back overgrowth around fields and along my paths. First read about it on TBN!
   / Favorote Quick Attach FEL attachments??? #23
Interesting, who makes those?
   / Favorote Quick Attach FEL attachments??? #24
Probably this one
Sabre Samurai | Features
Mine should be on the way, they finally billed my card yesterday. Their stateside warehouse was out according to the lady I talked to, and they were waiting on enough production to keep shipping costs down... Steve
   / Favorote Quick Attach FEL attachments??? #25
Nice. Now if they could make it extend and retract for going under a fence while driving parallel to it. It looks handy without that, but if it could extend it would be really nice. hhhmmmm, it would just be a mater of attaching it to a hyd cylinder, and maybe have that cylinder swing away if hits something too solid.
   / Favorote Quick Attach FEL attachments??? #26
Probably this one
Will look forward to your review... have been eyeballing this myself.
   / Favorote Quick Attach FEL attachments??? #27
Before I learned that a JD 4100 can have additional hydraulics added to it. This was our solution for digging and trenching. Frame from scrap around the stockpile and the bucket was $37 at the local scrap yard. View attachment 294115
I love it.
   / Favorote Quick Attach FEL attachments??? #28
#1. Ratchet Rake from Tractor Supply $300
#2. Bucket Solutons' clamp on Bucket Spade $380
#3. Payne's clamp on Aluminum Debris Forks $800
   / Favorote Quick Attach FEL attachments??? #29
Probably this one
We use one to maintain our horse trails. Its fine if you keep your speed down and dont try to cut much above 1" dia. It has a built in swivel to protect against bending overload, but still u need to take care.
larry
   / Favorote Quick Attach FEL attachments??? #30
Larry, I appreciate the heads up on being "gentle" - planned on it anyway, at least til I see the beast "in the steel" - which should be soon, the box just showed up from UPS, and apparently was too heavy to destroy like some stuff.
hchxoom, you may have to settle for Larry's "nutshell" for a bit, I still have about 37 other projects with higher priority before I can add 3 more hydraulic circuits on each end of my 580b to run this thing. My mind is now filling with "what if" ideas for it, so maybe by next fall I'll post some cool stuff... Steve
Broom Attachment (A59228)
Broom Attachment...
2018 HINO SA (A58214)
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
12' CONTAINER (A52706)
