Front-End Loader Favorote Quick Attach FEL attachments???
/ Favorote Quick Attach FEL attachments??? #21
Hydraulic post hole digger for front mount FEL. I don't have actual pictures of mine yet (these are stock pictures), but if you get one, make sure you get the offset set up (second picture) so you can see what you are digging. Otherwise if you get a center mount one intended for skid steers you may need a second person on the ground to guide you. These FEL mounts are way better than 3 pt as you don't have as much of the wobble that a 3 pt allows (sometimes holes then go at an angle) plus you can reverse the auger if you get stuck under a root or rock and can't lift the auger out. If you already have hydraulics for a grapple, you should be set. Otherwise you will need to add them. Make sure you don't oversize the hydraulic motor depending on your hydraulic GPM capacity.
/ Favorote Quick Attach FEL attachments??? #22
I ordered a hydraulic drive sickle bar which attaches to my bucket. This will be useful trimming back overgrowth around fields and along my paths. First read about it on TBN!
/ Favorote Quick Attach FEL attachments??? #23
Interesting, who makes those?
/ Favorote Quick Attach FEL attachments??? #24
Probably this one
Sabre Samurai | Features
Mine should be on the way, they finally billed my card yesterday. Their stateside warehouse was out according to the lady I talked to, and they were waiting on enough production to keep shipping costs down... Steve
/ Favorote Quick Attach FEL attachments??? #25
Nice. Now if they could make it extend and retract for going under a fence while driving parallel to it. It looks handy without that, but if it could extend it would be really nice. hhhmmmm, it would just be a mater of attaching it to a hyd cylinder, and maybe have that cylinder swing away if hits something too solid.
/ Favorote Quick Attach FEL attachments??? #26
Probably this one
Will look forward to your review... have been eyeballing this myself.
/ Favorote Quick Attach FEL attachments??? #28
#1. Ratchet Rake from Tractor Supply $300
#2. Bucket Solutons' clamp on Bucket Spade $380
#3. Payne's clamp on Aluminum Debris Forks $800
/ Favorote Quick Attach FEL attachments??? #29
Probably this one
We use one to maintain our horse trails. Its fine if you keep your speed down and dont try to cut much above 1" dia. It has a built in swivel to protect against bending overload, but still u need to take care.
larry
/ Favorote Quick Attach FEL attachments??? #30
Larry, I appreciate the heads up on being "gentle" - planned on it anyway, at least til I see the beast "in the steel" - which should be soon, the box just showed up from UPS, and apparently was too heavy to destroy like some stuff.
hchxoom, you may have to settle for Larry's "nutshell" for a bit, I still have about 37 other projects with higher priority before I can add 3 more hydraulic circuits on each end of my 580b to run this thing. My mind is now filling with "what if" ideas for it, so maybe by next fall I'll post some cool stuff... Steve
/ Favorote Quick Attach FEL attachments??? #31
I don't know how BukitCase can wait to utilize his new toy? I felt compelled to get mine hooked-up the day it arrived. Even though it was 14F weather! I'll manage tol get some pictures posted pronto.
/ Favorote Quick Attach FEL attachments??? #32
Louie, don't have a lotta choice - I'm still recovering from rotator cuff surgery, plus a complete right biceps re-attachment. Gonna be a while before my friends quit calling me "lefty"...
Also, I have several projects planned for the BH that will require 3 new hyd. circuits at each end - a 3 position, one with float, and a motor control/flow control for loader bucket AND for the hoe bucket. I'll need to run hard lines along the hoe sections and loader, then set up QD's for each, build a mount for the right fender for two 3-section valves, plumb it all up, likely add a transmission cooler in the return (flow controls tend to add heat) - All this in addition to modding the front bucket for QA (See Puckgrinder's thread) -
Hopefully I can get this all done before I croak, 'cause it will definitely make things a LOT easier to keep on top of if I'm doing it with little levers instead of BIG, NON-hydraulic tools :=)
Sooo, it's not like I'm actually WAITING - I'm just not DOing much... Steve
/ Favorote Quick Attach FEL attachments??? #33
Lefty, Sounds like you have a busy future. Good luck with all the upgrades and especially your recuperation. Getting this samurai was a big project for me -- tells you what my skill level is!
/ Favorote Quick Attach FEL attachments??? #34
Yeah, don't plan to be bored unless I live to be 180 :=)
I'd been trying for the last year to find a usable sickle bar for less than $1200 that was worth bringing home, followed by probably a month of messing around and another $600 in hydraulic parts/steel, etc, when the Samurai popped up (here, of course:=) so I consider myself lucky NOT to have had that particular experience (modding an old pitman arm relic trying to make it "petite" enough to handle, etc)
BTW, on their website FAQ's one of the questions was whether the teeth were smooth or serrated - the answer was "smooth, so you can re-sharpen" - yet mine showed up with serrated teeth. Same with yours? Just curious... Steve
/ Favorote Quick Attach FEL attachments??? #35
Here are a few photos of my new saw. The teeth are serrated, and appear easy to remove.
/ Favorote Quick Attach FEL attachments??? #37
I have several nice FEL attached implements...but my favorite HAS to be my snowblower. Its powered by a 3 point attached 25 gallon hydraulic tank hooked up to a 3,000 PSI, 15 GPM pto powered pump. I hope to add the loader mounted post hole digger some day.side view blower and bracket 1.jpgready to blow roof.jpg
/ Favorote Quick Attach FEL attachments??? #38
I have a front three-point adapter and use my carryall on the loader all the time. I find it to be very convenient to just go grab it with the loader when I need to move something and not have to drop the rear mower.IMG_2003.jpg A loader mounted trailer hitch is also very handy.IMG_1459.jpg
